N
NITROS Offline OP
N
I was wondering how much would it cost me, since i need suspension work it wouldnt hurt to upgrade to something better.
Springs and struts plus everything else i need(give me a list of things i need to do this). and is it possible to do it on a pre 98.
Experience is the worst teacher; it gives the test before presenting the lesson.
"You peel my onion down to the nun" - Gene Hackman [Under Suspicion]
-Walter-
96 Contour LX
Try brousing the classifieds. Lots of SVT suspension parts in there. I've been looking myself.
The only parts I know are springs/struts and sway bar(Might be better of with Aussie bar). I'm sure someone else knows what I may have missed.
edit:
http://www.contour.org/classifieds/classifieds.cgi?t=1&c=5
I see two adds for all three parts. One add wants $150 for the springs/struts and $50 for the sway bar(60000miles) The other has no asking price but only has 20000milles on the set.
Ryan French
98 Mystique Duratec Sport(KKM, Custom Exhaust, debadged/dedinged, Tinted, A4 sidemarkers(clear), Bodycolor grill...Suspension is next.)
00 ZX3 Zetec Limited Edition(nothing)
N
NITROS Offline OP
N
im actually looking for a brand new price, i want everything new.
-Walter-
96 Contour LX
If you are getting evrything new, get the BAT kit. Its just better than the stock SVT setup, with a mild (1.5 inch) drop.
Marco Tatta
98.5 SE MTX, Duratec
EGR block, fog light
fix, custom shift boot, monsterflow intake, Ecotek valve
Quasi dual cardoctor exhaust.
Hacksaw short shift, Momo race "s" carbon knob, ghetto rear strut bar, 16 inch cougar wheels with 225/50/16 kumho 712s
This might be a good question for Bill Jenkins parts guy.
Unless I'm mistaken the SVT uses the same springs as the SE sport, just that the struts are valved differently for the SVT.
"careful man, there's a beverage here."
e-mail: boseraq@hotmail.com
aol IM: madhat1412
Springs
Struts
Rear sway bar
Front sway bar
For the cost of buying the parts new you could buy the BAT kit and a sway bar(rear). Also, there was a difference in the spring seat from 97 to 98 so since you'd be upgrading to the later style you'll need new strut mounts IIRC...front only I think.
That BAT kit is an advertised 1" drop not 1.5". However, when installed on my car(BAT sport springs) the drop was definately NOT 1" all around.
NITROS
You might also consider buying the ST200 struts from BAT...I understand they're valved simliar to the SVT and are relatively inexpensive.
H
H
sq, was your drop more than an inch?
AIM:omegazodiac
95 gl
99 contour svt #1750/2760
built 4/6/99
black/tan
plates, not personalized (###-REV)
amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
9
9
keep in mind that install will be around $200-300
99 Tropic green svt
Custom Stereo
borla cat-back
22mm bat rear sway bar
custom K&N & heatshield
215/40/ZR17 Rubber
jimmkreider@yahoo.com
It would be cheaper to go aftermarket than buy new SVT Stuff!
-Andy
Andy Watson
'99 Silver SVT #2397| DOB 07/29/99
Graci!
American Iron Shoot Out - Event Promoter!
Check it out, we need your input!
Www Dot American Iron Shoot Out Dot Com
Installing a front sway bar will be more than $200-300 itself.
The subframe must be dropped!
The rear bar you can find at any salvage yard for $50 (95-97 SE or any SVT) - New for ~$100
The struts and springs will run you more than the BAT kit. So getting the BAT kit would be a no-brainer in my book.
2000 SVT #674 - Check it out!
