Posts: 142 |
With all the discussion of how the BAT bar is actually 20mm and the type of steel having no bearing on stiffness, should I ditch my bar and go through the trouble of trying to get a BAT bar and getting it installed?
Thanks,
George
George Hodge 2000 SVT Silver Frost 1188/2150 DMD HPP Rear strut tower bar SP Motorsports "22mm" sway bar BAT European Handling Kit
Posts: 804 |
Did you mean ditch a BAT bar that you already have installed and get an Aussie bar?
-Rob- '98 E0 Contour SVT #897, T-Red. FOR SALE: '98 E0 CSVT #2663 SilverFrost; stock & in very good condition. $7,800 KKM & BAT Intake Pipe, DIY cool air intake, Resonator deleted, TH fix; short shifter, rear spoiler, hood struts, fog mod, pre-98 sails, dings removed, A4 side-markers, clear head-light corners, T-red chrome front & back. Aussie Bar waiting for installation.
"Monkey is my business...and business is good!"
Posts: 142 |
Rob,
That's what I meant. It does feel like the BAT bar is doing good things. It's just a matter of how much better will it be going to the Aussie bar.
George
Posts: 4,528 |
I know Chris A. aka Shaggy ditched his for the Aussie and is very happy. The group buy is still going on. They only needed one more the last I heard.
Posts: 804 |
Originally posted by todras: They only needed one more the last I heard. It's still open, but they (we) are past the 30 minimum needed. Just an FYI...
Posts: 411 |
U are nuts if you do that.....unless you want to rip out your rear end.....
99 Tropic green svt Custom Stereo borla cat-back 22mm bat rear sway bar custom K&N & heatshield 215/40/ZR17 Rubber jimmkreider@yahoo.com
Posts: 7,329 |
Originally posted by 99badsvt: U are nuts if you do that.....unless you want to rip out your rear end..... That rear end come with axles too... :p :rolleyes:
Posts: 5,296 |
Hop in the Aussie GB before it's gone! Last day to have deposite in is April 30th. After that, my guess is that there will not be another GB for a looooong time.
