Originally posted by Dust:
I guess my only question left is why exactly do I want to have the larger rear bar to produce oversteer. I think I?m just getting all confused. Oversteer should allow me to drift into the corners and execute a slide around the corner right? Where as understeer will do what again? I would love to have an aggressive yet drivable car and going into a slide around a corner would be fine with me.
Your car now is baseline. The only way to make it produce more understeer is by removing the rear/both bars (I drove mine without the rear when I ripped the brackets off). Its not very fun. It feels like you are sitting on one of those air filled chairs and leaning to the side. Adding a larger sway bar to the rear isn't going to give you awesome, tire burning, smokey slides. All the times (except one, below) I have had it come right back in when it popped free. The only way I have found to make it slide more is by applying the e-brake, but that provides too much drag since the snow and ice have melted.
From what you are describing you want, I am almost positive that either a 22mm or the Aussie Bar would give you what you are looking for. The car is balanced almost perfectly (even though I only have a 4-cyl). It goes right where you aim it to go.
Right now my car is sitting on 205/60-15 all-seasons, stock height, with 104K on all the parts except the sway bar. I have pushed it as much as I dare, but it is still solid. I have only completely lost traction (all 4 tires!
) once, but it corrected almost instantly.
