I was wondering if anyone has changed the little flashing red LED on the dashboard (for the factory theft prevention module).
I tore it apart. It doesn't look too hard to do. I figure I could replace the LED that is attached to the electronics board, or wire in a complete new flashing LED unit into the same place and not mess with the original parts. In case I wanted to switch back.
I've seen some super bright flashing LED's but they are all a 3 wire system. I'm guessing pos, neg, trigger. So they wouldn't work.
Just looking for some suggestions from anyone who's done this already.
CM.
99 Mercury Mystique V6 Black
KKM, 9006 BV Bulbs, Painted Calipers, 16" Cougar Rims
Alpine 7894, CDT HD62DT front, CDT Coaxials rear, ,Mmats Pro 10's. POS amp. No RICE.
I was trying to look up parts online to see just how much it would cost if I mess this up.
The part # on the LED module is:
97 BG 15K603 AA
The part # on the whole assembly is:
XS2X-046B38-ABW
Neither one is listed on www.fordpartsonline.com. Is there anywhere else I could try?
CM.
all you have to do is go to radio shack and get a new led, any color you choose. I think I used 4.5 watts or something. Then just take a soddering pen, unsodder the old one, sodder in the new one. Make sure you take note of which wire is positive and which is negative. It does make a difference.
Black 1998.5 SVT with custom "Nascar Damage"
2
2
The shop that put in my alarm replaced the stock LED with the alarm status LED. They told me I could replace that one with a blue one if I wanted. Hmmm...maybe I'll give them a call.
2000 SE Sport V6
Deep Navy CC Metallic
My 2G Sport
Its not that easy if you have a dash clock,they use sufrace mounted LEDs(see tiny)and only use around 1 volt.Tried it...
Howard
1998 Silverfrost SVT #1612
June mods:
17" ADR RS Limited Limix Wheels
with 215/45/17 Yokohama AVS Sports
