Page 1 of 3 1 2 3
Krafty Offline OP
Well I finally had a chance to investigate the clunk I was getting from my rear suspension and it is not good news at all. I found the problem immediately, the passenger side mounting bracket and backing plate had torn itself from the subframe. Here is a pic of the bracket just hanging off the bar:
One of the subframe where the bracket tore itself free:
Underside of the backing plate:
Now as some you may notice, the upgraded backing plate was already added but I think 99.9% of the breakage occured prior to the upgrade. I spoke with Terry Haines about it today and he believes that the stock bracketry clamps hold the 24mm sway bar bushing too tightly and does not allow the bar to twist like it should, this causing the bar to put undue stress on the subframe and backing plate.
So to those of you with the Aussie bar I'd highly recommend getting the backing plate welded on ASAP and if you have not installed the bar yet, do the uprgraded plate at the same time. To those that used the stock bracketry for a while, check the stock backing plate thoroughly for damage before you get the upgraded backing plate put on.
For my car, I'm going to have Terry drop the rear subframe and mount new, higher strength backing brackets to insure that I won't have this problem again.
Learn from my problems, get those upgraded backing plates put in ASAP!!!!
Ryan
Latest Mod: Mirko Splitter
mr. krafty, fix your first pic
Spattmobili®
F
F
Sorry to see that. Makes me thankful that I live in the south. No road salt to eat up my car.
Speed kills, but it beats going slow!
Simon Langley
Black 98 SVT EO (#2119 of 6535)
269.3 FWHP, 195.4 TQ
14.123 @ 97.36
All go, and no show!
Vortech, Quaife, Driveshaft Shop Stage II axles, Magnecore Wires, Custom True Dual Exhaust.
CDW-27 1/4 Mile Registry
E
E
I feel your pain. frown Or should I say, I felt your pain?
Drivers side bracket ripped from car.
Ripped Stock Bracket
The new backing plate. I know the painting job isn't the best, but it was cold and my brush sucked. The black stuff is POR-15.
New super bracket!
I was amazed at how much better the car handled after the new, overkill backing plates were installed. I was actually suprised as to how much the stock **** could move. The car feels like I installed -another- Aussie bar!
· Jon Miconi
· 96 Contour Zetec ATX
· 80 Ramcharger 360 ATX
· 77 Ramcharger 440 ATX
Same thing happend to SQPlus... frown
Alex in Boulder,CO
95SE MTX
Fast...soon to be faster
84 Jetta GLI
Rice Burner laugh
H
H
the bar pictured is under the car. isn't the aussie rear stb go in the trunk? the rear lower swaybar goes under the car, correct?
AIM:omegazodiac
95 gl
99 contour svt #1750/2760
built 4/6/99
black/tan
plates, not personalized (###-REV)
amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
Lee Offline
The Aussie bar isn't an STB it's a Rear Sway bar. It connects the rear suspension together for load balancing and added cornering ability.
Lee Cox
In life begins responsability...
Project Car
ExDelayed, did you use 'L' stock instead of plate to reinforce? Get a longer weld bead on that way?
-Kurt
-Kurt
"I'm a little sceptical of that internet thing. After all, what's it got besides information?"
-DB, 1/97
eek eek eek eek eek
"If you're pushing crazy I'm all full up here."
{Black '96 Contour SE MTX w/ over 126k on the clock}
· Get the skinny here.
· Need a 96-00 Ford Service Manual on CDROM?
E
E
I used 1/4" thick angle iron. laugh I had to notch the side of it so it would fit over the subframe. Its welded to the subframe on both sides of the bracket. There is a weld where the flat (mounting surface) part hits the subframe. The outerside of the bracket is also gusseted there too.
I am off tomorrow so if you want to see pics I can jack up the car, take the tire off and snap some. Its hard to digi-cam, upside down and through suspension parts.
· Jon Miconi
Page 1 of 3 1 2 3
