Oh yeah, and how much do they hang down below the car? I don't mean how much lower than the SVT side skirts, but how much lower than the little lip we are supposed to use for stock Jacking points
Basically, once the rear is placed you will see how the front is set. It is just angled towards the center of the car and runs along the frame rail. The connectors are attached via welds so there is no hardware or any types of brackets, the tubing is simply welded to the frame.
Man, was I waaaay off in where I thought they'd go or what???
If you can post some pics of the front ...it would be great as well!!!
99 SVT (Black) # 2642 of 2760 Mirko Racing Intake \K&N Filter (RU 3130) BAT Air Inlet Pipe HD Motor Mount Inserts \Front - Rear Sway Bar Bushings BAT 22mm (Rear) Sway Bar, Bat Springs \ Koni Sport Struts Performance Fords - Spherical Rod End Links (Rear) Performance Fords - Street Link SHO Shop Strut Tower Braces (Front and Back) SHO Shop Body Sub Frame Connectors Aeroquip Stainless Steel Brake lines (Front/Back) Sho Shop "Y' Pipe Magnecor Wires \ Bosch +4 plugs Ford Dual Mass Crank Damper Pillar Guage Pod Perma-Cool Remote Oil filter Mount Summit Racing Polished Almn Battery Relocation Kit MSDS Headers (not installed) B&M Short Shifter Sparco Pedals (4 pedal set) (I think I got 'em all)...someone sell me something else!!
