Page 2 of 2 1 2
It is called a spring compressor and you can get one at any O'reily's. You have to give a deposit of 50 dollars and when you return the tool you get all the money back.
95 contour (All the usual mods and then some.) Trying to sell four wheeler so i can buy turbo.
1
1
That's for taking the knuckle off the ball-joint not the tie-rod end. I never use any seperator for the tie-rod end, but I used it everytime except the first time for the ball-joint. Maybe the 98+ is easier, but for the horizontal bushing type control arm on the earlier cars, it's harder to take the knuckle off.
Originally posted by sagittarius:
Airknight
Also get yourself a ball-joint seperator to put the ball-joint back on
Why? How? I saw the separator tool in the haynes manual for removing the outer tie rod end joint. But a slight tap with a hammer and the tie rod end bolt poped out of the knuckle. How and why would a ball-joint separator tool be need for removing the knuckle?
UBRF.org , Western New York's Premiere Automotive Forum.
Yeah, I got some bolt-ons.
Car Pics
Video of Brullen cat-back on a \'95 SE
How-to: Short Shifter for Pre-98 MTX
"heres the deal $2 grand buy in winner gets the cash and the girl and the respect. We'll race from 0 to Inf. until I win." - someone on the internet
OK AirKnight, that seems to make more sense. In the Haynes manual the same tool is mentioned for use in removing/separating both the lower control arm joint, and lifting the outer tie rod end out of the steering knuckle. A picture of the tool was given in outer tie rod end removal section. In either case I don't think the tool is needed, but you are right, it may make the lower control arm joint removal a bit easier. Thanks for your input.
96 2.5L SE manual
99 4.6L F150 XLT 4x4
Page 2 of 2 1 2
