Posts: 852 |
Basically he cut four slits into the top of the tower going from the outer edge to the middle, so now his tower looks like a 4 slice pizza, then he took a BFH and pounded on the towers until they were flat, next is to weld your cuts back up, grind to a nice finish and mount your camber/caster plates. gutsy...
Marco Tatta 98.5 SE MTX, Duratec EGR block, fog light fix, custom shift boot, monsterflow intake, Ecotek valve Quasi dual cardoctor exhaust. Hacksaw short shift, Momo race "s" carbon knob, ghetto rear strut bar, 16 inch cougar wheels with 225/50/16 kumho 712s
Posts: 115 |
Not really gutsy when you consider who Leo Capaldi is check out his website
2000 Cougar V6 MTX Black Visteon GFX Kit with Razzi rear skirts, Ground Controls, YoDude Exhaust, Ractive Filter, Custom Interior, Custom Loud Stereo, and more... See Her Here
Posts: 2,794 |
I would do it....if someone had a welder and the time I could pull that one off....just buy the plates so I have a reference.....not a problem.....
Just call me Judge. People suck. Life begins at 170mph...until that point it is just boring.....
Posts: 2,481 |
I like trying new things when it comes to modifying our cars, especially since I am not going to have this car forever! Okay, i'll like to be the first on this one Brian.  :p
99 Range Rover 4.6 HSE Mystery Car??????
Posts: 2,794 |
Sounds like a big install day at Dougs......If someone wants to see if we can us e a bay and a welder....heck I am up to it. I have done bigger modifications than this one....repaired a broken frame (2 spots) on a full size Truck, replaced a rusted frame section on a Mustang....and the list goes on. All we need to do is pull the front struts the night before (like Fri night) that way the mods can begin early sat AM.....cmon lets do this bro.....
Posts: 3,237 |
So were are you getting the camber pl[ates from?
PS you have to remove the old conical support from underneath the strut tower before you can install something like shown above.
PPS I ask K-MAC if they had anything for aour cars (Australian Suspension Gurus) and they said that noone had ever asked for it, so they hadn't developed anything. They just need a car. Too bad we don't have many Australian members. I only know of 1 actually still living in Australia, andd he probably in the wrong state too.
Posts: 2,794 |
I guess Mike will have to locate them, as far as the rest.....just have to pull the struts and start modifying......where is your sense of adventure????? :p
Posts: 2,481 |
What does Mondeo offer in regards to camber plates? I thought that Terry had some development going on for these plates.
Posts: 2,794 |
Ya know I have not heard anything about his adjustment plates. Tehy sounded sweet too.....something to do with the lower control arm I believe.....not cutting /welding needed....but I want to cut and weld something.....something big......something black.....like your car....
Posts: 2,143 |
Originally posted by mike016: My first set of tires wore on inside(stock). Toe setting was causing it more then chamber. My car is lowered and tires are wearing evenly. A friend of mine, owner of Morris Eng. Suspension is curently working on chamber adjustment plates for celica and neon. Said he will take a look and see if he can make some for contour. Probably within a month, when he can find time. If he can i'll post something in GB if anyone is interested. please do, would be very appreciated!!
'95 Tour LX ZETEC MTX TOO MANY MODS TO LIST ANYMORE!! http://www.geocities.com/marine113 Best mod ever to my tour: A Beautiful passenger seat filler, that is my Beautiful Girl!!
