Posts: 3,237 |
Originally posted by redhawk:
Yeah... I was a little confused by that and the "Eiback" comment... Yes, lowering a Macpherson strut equipped vehicle WILL give you negative camber. But when you say "dial in" that usually means you deliberatley adjusted something. Hence the term - dial. In the case of our cars, camber adjustment out of your control. It's just a byproduct of lowering. So I was commenting on the fact that it sounded like ssmumich00 was saying that he adjusted the camber by some sort of alignment process which I called BS.
Posts: 2,906 |
I have my rear on FULL stiff and front on HALF stiff. The handling is very predictable and you should not have any problems with over steer unless you driving like a bat out of hell around every corner. I drive very hard thru corners and I have to be going ridiculously fast to lose it.
As far as being "squirrely" on the freeway as L8apex stated...I have no idea where that came from. My car has never been squirrely in any situation no matter how fast I was going. You should be totally fine on freeway with bumps.
The reason I have the back so stiff is because of the FWD bucking under acceleration. The stiff rear keeps the weight from moving so hard to the rear keeping the front flat and the front wheels get more traction. Not alot but way better than before.
Josh Aka Spectra SVT 02 Dark Highland Green F-150 XLT Mods: Gunrack and cowboy boots
Posts: 1,812 |
how much of a pain is it to adjust the struts? what does it entail?
2000 Silver SVT #1602 Check it out in the registry! Mi Coche
Posts: 446 |
Take the knob out, put it on the top of the strut, and twist it either left or right depending on whether u want it soft or hard. Pretty simple. Peace. ><>David<><
"this world has nothing to offer, come back soon." luti-kriss throwing myself an act of my own violation '98 Black SVT- 3949/6535 8k miles ticked away, Eibach springs, Koni Struts, SHOShop CAI, Ford 9mm racing wires, deleted res., lead foot...more to come. http://community.webshots.com/user/svtminiflea
Posts: 1,083 |
Thanks for all the replys. I guess this means i should have no problems.
1998 SE ATX Dual exhaust Body conversion Nakamichi CD-40z HU Sound by Crystal Mobile Powered by a/d/s M860 AMP My Ride
