Posts: 23 |
I didnt really want to spend a lot of money performance wise on my 98 v6 auto, but this car handles terrible. Will just the addition of a larger swaybar make a big difference?
How many of you are now satisfied with just a larger rear sway bar?
Please help my car out
Posts: 2,915 |
i have no knowledge of sway bars, but if you are interested in springs/struts let me know i can get you a good deal
www.shox.com Dealer Koni's 135 a piece Eibach's 190 a set KYB's 70 a piece H+R's 225 a set see profile for website, aol name, etc Business:WestEndMobil@yahoo.com Personal:Corey_pimp1@yahoo.com 1998.5 SCSVT ($16000 takes it) 2001 GSXR-1000 1988 Corsica (the beater)
Posts: 1,181 |
I am very satisfied with my larger rear sway bar, and its only a 19mm. The loss of body roll during cornering is very noticeable. If you're looking for a drastic change, buy the BAT 22mm one or the Aussiebar.
98 Merc. Mystique LS
Red Wings and US Soccer 0wn j00!
Posts: 7,329 |
Aussie bar.
Live it, love it, learn it...
Though starting with a 16mm rear you may want to go to the 19mm. Quite a big jump to the Aussie bar, just by itself...
Posts: 3,934 |
Originally posted by DemonSVT: Though starting with a 16mm rear you may want to go to the 19mm. Quite a big jump to the Aussie bar, just by itself... Bwah! I am making that considerable jump right now.
· Jon Miconi
· 96 Contour Zetec ATX · 80 Ramcharger 360 ATX · 77 Ramcharger 440 ATX
Posts: 7,329 |
Originally posted by ExDelayed:
Bwah! I am making that considerable jump right now. Do it... Just make sure to take many test drives to feel out your new suspension mod. As many times as you can. Matter of fact just stop to eat and sleep if necessary...
Posts: 3,934 |
Well, I made the jump. I am very happy going from the little tiny bar that I had to the Aussie Bar. I have yet to be able to do any real stuff (ie: canyon carving) but for the corners I have done, the car now goes where I point it. There is quite a bit less body roll when you wiggle the steering wheel too. Only drawback, I can EASILY lift a back tire going into any kind of approach. Before I had to actually try. :rolleyes:
· Jon Miconi
Posts: 168 |
My advice: get a big bar, ie Aussie, BAT, or SCA. The handling improvement is great. But keep in mind that you will need to upgrade the mounts to keep them from pulling out of the subframe :rolleyes: . Not a big deal to upgrade though, you just need someone to do some welding.
-Kurt
-Kurt
"I'm a little sceptical of that internet thing. After all, what's it got besides information?" -DB, 1/97
Posts: 3,934 |
Originally posted by Munson: But keep in mind that you will need to upgrade the mounts to keep them from pulling out of the subframe :rolleyes: . Not a big deal to upgrade though, you just need someone to do some welding. Yep, I now reccomend that as well. I managed to pull one of my mounts out of my subframe.
· Jon Miconi
