Originally posted by Bradness:
Roger: When you say "You (or your compatriots) are clearly talking about area. If you were referring to linear distance, the above example would yield 6 inches.", what math are you using that gives you 6 when multiplying 3 times 4?
Just for you, I'll change the wording to read "linear periphery", instead of area. I believe that everyone else understands my comparison based on the terminology used. Of course, if I was talking about a circle I could have simply said circumference and you wouldn't disagree with that would you?
A "stitch weld" of 1" welds with 1" gaps over 12" of available space would yield 6" of weld and 6" of gaps. If you are talking weld length, that is what you would have.
When the weld is solid, then you have a 12" circumference that is all weld with no gaps. "Circumference," IMHO, will work even if the object measured is not round.
I'm not sure how it would be clear to everyone else that you are talking circumference when you say "square inches of area."
As for your comparison, let's talk real attachment area, so we can compare apples to apples. How wide is a weld? I don't know for sure, actually, since I'm not a welder, but let's say it's .25" wide by 12" long. That would mean the actual area of the weld is 3 square inches. OK. What if it's .5" wide all the way around the bracket? That would be 6 square inches. 6 is quite a bit less than 12, but still more than 4.712 (the bolt area), and at least we're making a valid comparison based on the same units. Your comparison inflates the difference by comparing length to area without really saying that that's what you are doing.
Does it matter? Not really. I think most of us understand rather intuitively that a welded joint will flex less than a bolted one. I know there is a technical, scientific explanation for this phenomenon. I'm still looking for it.
I only brought it up to help you, as a friendly jibe from one Contour family member to another. I took a risk I guess and it seems that I've pi$$ed you off. Worse, the two of us are involved in this little pi$$ing contest, and that was really not my intent, especially over such a minor point.
Thanks for giving us more choices, and good luck with the STB.
