Page 4 of 6 1 2 3 4 5 6
Roger, your comment "...what's 3 x 3?" Where did you find that? I am not the
webmaster, but I will look into it.
In the technical discussion of Welding vs bolting the Rear STB, the following appears:
Now let?s compare these numbers to a weld-on arrangement. The mounting/backing plate is 3 inches square. If the backing plate is
fully welded around it?s perimeter, we have 3 (inches) times 4 (sides) = 12 square inches per side times 2 (sides) = 24 square
inches! Even if a stitch weld technique is used and we assume a 1-inch space between 1-inch welds, the weld on attachment
technique provides 12 square inches of area vs. 4.712 for a bolt on arrangement.
The area of a 3x3 square is 9 sq inches. Not 12.
"Function before fashion."
'96 Contour SE
And Brad, I wasn't busting on your use of the word "best."
Just trying to offer potential consumers an "outside the box" notion. Perhaps the best product is the one that works almost as well but costs less than one-fifth as much to do. (I'm not sure if this is workable for us, though, or not.)
BTW, any claims you make in the interest of marketing, you'd better be able to back up with at least consumer perception. In your case, you seem to have a good product. It's up to us to decide the rest.
'96 Contour SE
Like I said, even if one of our tires was unloaded in a cornering event it would not create a tension situation...just not as much compression on the bar.....
Just call me Judge.
People suck.
Life begins at 170mph...until that point it is just boring.....
Errrr...the top of each spring is rubber mounted to the body soooooooooo......!!!!!!! laugh
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
So therefore it would have to pull far enough that it was tearing the rubber before it ever got a chance to pull the sheetmetal far enough to put the rear strut tower brace in tension...... wink
Just call me Judge.
People suck.
Judge your smart man.....
1998.5 T-RED SVT
18" Team Loco 142's W/ Dunlop Rubber
181.2hp@6900rpm/155tq@5000rpm
LOTS OF MODS OF EVERY KIND....
...Am I a guru yet??? No... not yet.
Administrator
Administrator
If your STB is gonna see anyhting significant in tension loading, you have FAR more more to worry about than the STB. The geometry just isn't there for it to happen under normal circumstances.
1sick puppy is completely, yet humorously smugly, correct.
It's all about balance.
bcphillips@peoplepc.com
I figure this is obvious, but since no one has posted yet...
RogerB, my understanding is Bradness is talking about 12 inches of LINEAR weld metal. There is no way I can think of you can fill the entire bar mount to strut surface with weld metal (Unless you whip out the JB weld... wink . You have to go around the perimeter, so 12 inches would be the perimeter of the mount...
But then again, I didn't design the bar...
Marco Tatta
98.5 SE MTX, Duratec
EGR block, fog light
fix, custom shift boot, monsterflow intake, Ecotek valve
Quasi dual cardoctor exhaust.
Hacksaw short shift, Momo race "s" carbon knob, ghetto rear strut bar, 16 inch cougar wheels with 225/50/16 kumho 712s
Still ,the fact is the struts can still flex dispite how stiff the tower is made due to the rubber mount cones on the top of each strut/spring assy...... wink
V6 MTX
Administrator
Administrator
Good point, I'm gonna go weld my struts to my strut towers right now!!!!! wink
