V
V
My rear suspension has started sqeaking ever since the meet in Sacramento.....The bay area guys now the best way to stop it, but I don't remember what it was..........!!!!!
1996 GL Zetec MTX
H & R springs
KKM intake
Strut braces both front and rear
door dingers removed
2.25 inch exhaust
side markers
4 point racing harness's
soon to have 19's!
i think IRON MIKE has the answer!!
Todd Christ SVT Contour Registry
MODS: KKM Intake, SHO Shop Y-Pipe, Bullit Fuel Door, Edelbrock RPM Resonator
'98 E0 SVT Contour #1037 of 6535
F
F
Adding any of the larger sway bars will increase squeak. I have the SCA 21mm bar and you just have to keep em lubed up.
I have been using this Free Astroglide Lube and since its water based it just doesn't seem to be working very well.
Actually was using White Lithium Grease but it still doesn't last too long. Will have to try the Marine Grease and shallow grooves.
I was thinking of going back to squeekless rubber bushings, since I have the 21mm bar I figured I wouldn't notice that much of a difference.
I recently purchased a tube of Chevron Marine Synthetic Lithium High Pressure Grease from Wal-Mart, in the auto section, and it seems to be working well.
I just need to order the Aussie backing plates cus my stock brackets bend after about 2-months and I get the dreaded bang everytime I hit a minor bump.
You don't use Mobil 1 with your woman, do you? wink Sorry, I coudn't resist.
F
F
Might this have something to do with that ebrake cable TSB?
A good number of people complained about this squeak and were told to replace their bushings, but many still had the squeak until they did the ebrake cable fix.
Kim
2001 Mercury Cougar C2
1995 Contour GL
Quote: Originally posted by shotwell:
Yeah, I keep checking too. I'm afraid that just as the site goes down my car will burst into flames or something (knocking rapidly on wood)!
Do what I do... turn up the stereo! :p
-Jeff
-"The Crazy Canuck!!"
-"Rice": Anything that looks faster than it really is...
My Ride! http://members.sounddomain.com/sideoftheroad
i have a pioneer deh-p8000r head with a 2200 us acoustics amp and 2 ,12" JL W3s. it seems to kill all noise damn good. laugh
'95 Tour LX
ZETEC MTX
TOO MANY MODS TO LIST ANYMORE!!
http://www.geocities.com/marine113
Best mod ever to my tour: A Beautiful passenger seat filler, that is my Beautiful Girl!!
F
F
Dealer 3 years ago cleaned and lubed the inside of the stock swaybar bushings with dielectric grease.
Been quite ever since. Of course at 56 I may not be hearing. Eh! i hi
Paul
No but it did work.
98 Mystique LS built 7/97
I hope to be getting the Aussi bar soon, just so I can stop this squeaking before it starts wink where do you suggest lubing exactly?
Marine grease. Non water soluble. It's last's the longest & it's cheap too...
My fronts are finally squeeking (took almost 2 years with ES bushings - not bad for poly IMO)
Rear bar is still quiet though that was changed last spring...
2000 SVT #674 - Check it out!
