Page 4 of 11 1 2 3 4 5 6 10 11
#392762 03/13/02 06:44 AM
1
1
Any word on when I'll be getting my set?
Silver Frost 2000 SVT #1443 of 2150
Mirror Tint/ Momo shift knob/ Kurtz Kustom pedals
Ventshield raingaurds, moonroof and hood bug deflectors
True Rev Induction Kit/ BAT Air Inlet Pipe
Philips HID kit/ PIAA superwhite fogs/ Chrome Gas Bonnet Lifters
Top of line Alpine system( NVE-N851A, DVA-5205, IVA-C800, TUE-T011A, KCE-150V, CHA-S624, PRA-H400), PPI (PC 4100, PC 2150,PRO 10's), Image Dynamics CD2 Comp MH and IDQ-62.
Motorola Timeport HF car kit
Looking to increase performance!
http://photos.yahoo.com/hpick1
Future Mods waiting to be put on:
Lotek Guage Pod w/ volt, a/f ratio, and oil pressue.
Blue neon undercar kit
Aussie Bar w/ upgraded backing plate
Bullitt Fuel Door
Magnacore Wires
Ground Control Kit w/ Koni Struts
#392763 03/13/02 01:22 PM
They go out this week for the 2nd batch.
Regards,
Anastazi
Father of the Aussie Bar
anastazi.sarigiannis@aam.com
#392764 03/13/02 03:56 PM
Lee Offline
Yeah!
(Lets just hope they don't play Postal Hockey with this batch wink )
Lee Cox
In life begins responsability...
Project Car
#392765 03/14/02 08:18 PM
Just sent you a paypal. Ordered bushings/brackets from macsprings. Would recommend upgrading to everyone with an aftermarket bar. I've got the SP motorsports bar and it was fine until I had to drive to work on roads that were covered with rutted ice (the usual March winter storm we get in OK). One bracket completely broken and the other is torn 1/2 way thru! eek
Thanks Aussie!!!
98 evo 0 SVT
#2999 of 6535
Silver Frost/Midnight Blue
Lotsa bolt-ons
#392766 03/15/02 02:26 AM
E
E
aussie, am i on the list for the 2nd bunch?
**HELP SAVE CEG!!! DONATE NOW!!!**
*This space for rent*
Please call...
1-800-FOR-ELKY
All proceeds go towards saving CEG
#392767 03/15/02 03:39 PM
Second batch hich I just finished addressing will go out today (guys I DO have a real job, so I appreciate the patience with all this "govt work" I do for you guys).
Anyhow here is the list:
Jason Holmes
Nishkalan Vijayasundaram
Colin Berger
Valerie Robertson
Justin Hogan
Marla Kerr
Joshua Lewis
Michael Gluck
Christopher Nigro
Jon Miconi
Max Leonard
Brian Candiloro
Richard Cox
If your name isn't on here, it's because I ran out of plates, so you will get them with the 3rd batch next week.
Thanks in advance to everyone.
Regards,
Anastazi
#392768 03/19/02 02:03 PM
I admit I have been slow to get detailed instructions on the installation of the plates, but here goes:
1)Unbolt the stock bracket form the subframe and pull down on the sway bar(if you already have the Aussiebar installed, just pull it down as far as you can, there is no need to remove it from the vehicle).
2)Bolt the new plate to the stock backing plate (using the existing bolt and hole)with the holes closest to the edges facing forward in the vehicle. The plate with bevelled edges should go on the drivers side to clear the gas tank. (This aligns the backing plate to the subframe)
3)Weld the plate to the subframe and the stock backing plate. You should be able to weld 3 edges, the forward edge is in "space" so you cannot weld it to anything.
4)Remove the bolt and grind down and high spots from welding.
5) You now have to drill through the pre-existing hole in the upgraded backing plate and thus through the old stock backing plate to allow you to use a bolt in the front hole. (Make sure you don't drill into you gas line on the passenger side mount!). Paint the backing plate and welds with a good rust proof paint.
6)Drop a suitably sized bolt with a washer down through the front hole so it is hanging down.
7)Reinstall the Aussie bar with the poly bushing AND the upgraded Prothane BRACKET onto the welded-in backing plate. screw the stock bolt in the back and use a nut on the front hanging bolt. (Make sure the Aussiebar isn't sitting too far back and is hitting the subframe).
You're done!
I'll try and get pics of an installed backing plate from my car, although it's hard without a hoist.
Regards,
Anastazi
#392769 03/22/02 11:10 PM
E
E
I got my new brackets today. Thanks Aussie!
laugh
· Jon Miconi
· 96 Contour Zetec ATX
· 80 Ramcharger 360 ATX
· 77 Ramcharger 440 ATX
#392770 03/23/02 10:11 AM
E
E
laugh
Just in time also. My car now only has 1.5 stock sway bar mounts.
mad
· Jon Miconi
#392771 03/24/02 01:24 AM
Just sent Paypal, thanks.
My stock plates are about to tear apart, if they do is it near impossible to mount these? Anyone have them rip right off the subframe?
Thanks again.
98.5 SVT Contour
T-Red/Midnight Blue
