Page 1 of 11 1 2 3 10 11
#392732 02/01/02 09:41 PM
Seeing as a few of us are having issues with the rear sway bar backing plates breaking, I have come up with a solution to fix and/or prevent the rear sway bar mounts from breaking due to upgraded sway bars being installed.
I just got the material for the backing plates, so I have the upgraded weld-in backing plates almost done. They will be completed this weekend. I have 14 sets. They will be shaped and predrilled, so they just need tot be welded in when you get them. $10 per pair (one pair required for each Aussiebar equipped car), plus $3 to ship.
If you want a set you can PayPal me the $13 using my email address below. Put "Swaybar Backing Plates" in the subject of your PayPal.
Terry Haines will be developing some in the very near future for supply with the AussieBar Kit, this is just for the time being as I know Terry is VERY busy right now.
So for now I am just trying to help some people out seeing as I supplied the first batch of sway bars, and I feel somewhat obligated to help those in need. I do not intend to do this forever, as Terry Haines is the authorized ditrbutor of the AussieBar, and he is my friend. I do not intend to take business from him, in fact I will most probably relinquish the design of my plates over to him so that he can use it, or modify the design and then supply it as an upgrade with the sway bar packages he is offering.
So for now if you need a set of backing plates let me know.
Regards,
Anastazi
Father of the Aussie Bar
anastazi.sarigiannis@aam.com
#392733 02/01/02 09:54 PM
Well, I guess you already know I want some. wink I may be getting this fixed tommorrow so I'll have to see. But, go ahead and send me some though.
Edit: You've got mail.
#392734 02/01/02 10:34 PM
I'll take a set! Paypal away...
#392735 02/02/02 07:54 PM
Yeah guys, Get these. I had some fabricated about 1.5 weeks ago before aussie was making them. But, they are very similar to what he is making. Buy them. Thats super cheap and it really made a nice difference!
Joe
1998.5 T-RED SVT
18" Team Loco 142's W/ Dunlop Rubber
181.2hp@6900rpm/155tq@5000rpm
LOTS OF MODS OF EVERY KIND....
...Am I a guru yet??? No... not yet.
#392736 02/02/02 10:56 PM
... just paypal'd you Stazi.
Black 98.5 SVT w/ KKM intake, 73mm MAF, ASP pulley, Optimized stock Y-Pipe, 24mm hollow rear sway bar, Magnaflow resonator, Magnaflow mufflers, Roush springs, KYB struts
#392737 02/02/02 11:56 PM
Could these possibly work with the stock se bar (18mm)? I really need to do something, I have a feeling my bracket slots are worn and the brackets are loose....
Marco Tatta
98.5 SE MTX, Duratec
EGR block, fog light
fix, custom shift boot, monsterflow intake, Ecotek valve
Quasi dual cardoctor exhaust.
Hacksaw short shift, Momo race "s" carbon knob, ghetto rear strut bar, 16 inch cougar wheels with 225/50/16 kumho 712s
#392738 02/03/02 02:46 PM
These will work with ANY Rear Sway Bar, as long as you buy the right sized Prothan sway bar bushings and brackets to go to the two-hole design.
Regards,
Anastazi
#392739 02/03/02 02:49 PM
Sway Bar Brackets are available from JC Whitney or from these guys http://macsspring.com/
VERY IMPORTANT - They have to be the small, "A" style, brackets!! Otherwise they won't fit the subframe.
Regards,
Anastazi
#392740 02/03/02 11:02 PM
How think are these backing plates Aussie?
1999 Amazon Green SVT Contour (#554/2760)
Stock SVT Duratec V6 with:
Intake- K&N filter/75mm MAF meter
Exhaust- MSDS Y-pipe/Bassani catback
Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter
179.2 FWHP at 6900 RPM
#392741 02/04/02 03:10 PM
1/8" which is about twice as thick as the stock sh!t.
Regards,
Anastazi
