Posts: 253 |
I've got a 1998 se and have the horizontal bushings. how much will these a-arms cost? my passenger side a-arm is ovalized around the bushing due to a bad incident with a curb. the hub also aparently may be bent as it "wobbles" when spun off the ground. the bearing doesn't make noise and has no play. the wheels are all new and it will wobble with other wheels.
don't drink and drive.
Posts: 3,237 |
I DEFINITELY need the newer style A-arm fix. My front bushin on the passneger side front is so bad that the A-arm has move up as far as it can go and is practically hitting the subframe. Sometimes you can hear it hitting when accelerating fast out of corners!!! Terry, how much for two replacement A-arms with my cores? Please email me.
Posts: 98 |
What kind of symptoms would I have if I needed these?
My wife was forced onto a median late this summer, and we still have not taken the car in for the minor body work needed. Something in the suspension does not feel quite right to me, but I can't put my finger on what. Today I noticed (maybe, it was dark) that the driver side (jumped onto the curb with this side) wheel leans more than the passenger side when parked with the wheels turned sharply.
Does it sound like I need one? We plan to take it in after the holidays, could I have the body shop buy the parts from you? Can I just do the driver side, then do the passenger side later? (I can't afford to put out any $ on it right now, I've got way too many other things on my plate.)
Thanks, Dave
98.5 SE/sport/MTX Brembo rotors w/KVR front and Mintex A/F rear Pro-Flow 75mm MAF w/KKM filter-Nice! Mobil 1/K&N oil ES MM inserts waiting-I can't get the bolt loose...need a bigger breaker bar:( Aussie Bar and Euro ST200 struts soon! Major mods to stereo system Clarion 9255 All Phoenix Gold processors/MPS amps! Vifa/Adire drivers
Posts: 68 |
I would definitly be interested in the A-arms with camber adjustment.
That just might make me choose a set of Ground Controls over regular lowering springs...
Posts: 115 |
I want camber adjustments... And I can go to your shop and get this done direct. Let me know when you are ready to release them... oh and i'll repeat everyone else... How Much?
2000 Cougar V6 MTX Black Visteon GFX Kit with Razzi rear skirts, Ground Controls, YoDude Exhaust, Ractive Filter, Custom Interior, Custom Loud Stereo, and more... See Her Here
Posts: 6 |
I am all about the camber adjustment. Will these work on the cougar? And, how much are we talking??
Thanx Klapper24
Posts: 3,934 |
Right on. Looks like I have something else on my list come spring. Since I have decided that my struts are going, and my strut mounting plates are almost gone, this will be perfect timing. Car will pull into the garage stock, and pull out with new suspension. Rock on.  Prices please Terry. I will be going with the poly pieces.
· Jon Miconi
· 96 Contour Zetec ATX · 80 Ramcharger 360 ATX · 77 Ramcharger 440 ATX
Posts: 460 |
I am interested in the adjustable camber A-Arms as well for my Cougar...
Nikolas
1999 Mercury Cougar V6 KKM Intake,SVT TB, SVT Upper/Lower, 19lb injectors, Diablo Chip, MSDS Headers, Custom Exhaust, B&M Short Shifter, Progress Lowering Springs, 18" Axis TC's, OMP Strut Bar, AAM 24mm Rear Sway Bar, Koni Struts
15.09 @ 91.54(corrected, pre-SVT conversion, DiabloChip, and Injectors)
Posts: 176 |
are you going to offer a stronger A arm. like a brace. also is this a do it your self thing and then go in and have it alined.
98 SVT Black #3502 BEL_SVT@home.com
Posts: 1,444 |
i know i'm an idiot but what do the a arms do. whats their role in the suspension.
AIM:omegazodiac
95 gl 99 contour svt #1750/2760 built 4/6/99 black/tan plates, not personalized (###-REV) amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
