Tarzann Offline OP
Despite asking several people, the answer seems to hover abound 50/50 yes/no.
So maybe here I get a bunch of answers from better informed people.
Are the springs and struts the same on the SVT and SE? Would a set of springs from an SVT be an upgrade for my 98.5 SE?
I just bought the ST200 struts from BAT and wonder if I should look for a set of SVT springs from someone who has upgraded to install at the same time.
Thanks,
Dave
98.5 SE/sport/MTX
Brembo rotors w/KVR front and Mintex A/F rear
Pro-Flow 75mm MAF w/KKM filter-Nice!
Mobil 1/K&N oil
ES MM inserts waiting-I can't get the bolt loose...need a bigger breaker bar:(
Aussie Bar and Euro ST200 struts soon!
Major mods to stereo system
Clarion 9255
All Phoenix Gold processors/MPS amps!
Vifa/Adire drivers
I believe the springs are the same on later years (98+) but the struts are valved differently. 1st gen S&S are stiffer but the skid pad numbers are very close.
"If you're pushing crazy I'm all full up here."
{Black '96 Contour SE MTX w/ over 126k on the clock}
· Get the skinny here.
· Need a 96-00 Ford Service Manual on CDROM?
Don't know about your car, but my early SE has the stiffest springs of any Contique (SVT included). Apparently, the strut valving is the same for the early SE's and the SVT's. Check the FAQ section, specifications IIRC.
Technical Director/Co-Owner Performance Fords-check out our new throttle body service
95 SE with lots of custom 1 off mods. All design, fabrication and installation by owner.
The write ups said that the 98SVT used SOFTER than SE (from the zetec?) springs up front along with firmer shock valving to reduce understeer (along with the smaller front antiroll bar). The 99 SVT used even firmer shock valving all around to reduce brake dive & front lift on acceleration IIRC. I think the SVT struts are not shared with any SE, though the rear struts are I believe - though I have NOT looked to varify this.
1999 Amazon Green SVT Contour (#554/2760)
Stock SVT Duratec V6 with:
Intake- K&N filter/75mm MAF meter
Exhaust- MSDS Y-pipe/Bassani catback
Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter
179.2 FWHP at 6900 RPM
I can verify that my struts are specifically marked as "SVT" exclusive since they are sitting in my garage as I type this reply.
The springs still retain their assembly line tags, but they do not contain any SVT specific identification.
But it was my understanding both the springs & struts were unique to the SVT model. At least that is what all of my factory literature claims.
1999 SVT Contour, #2140 of 2760, Tropic Green - Medium Prairie Tan
Koni Sport struts; TSW Blade wheels; Nakamichi, a/d/s/, Boston Acoustics, Infinity I.C.E.
1989 Saleen Mustang, #89-0408, too many mods to list here
Z
Z
i am just wanting to lower my 98 tour SE...would svt springs and struts do the trick
98 tour SE
Resonatorless
Gutted cats
some speakers
A little bobbin head cat watchin every1 pass
and ford mud flaps(darn fishin trips keep me muddy)
added all terrain tires(i like to pretend im rally racing, whne not really racing)
Master P
Master P
For the 98+ SE/LS V6 MTX's and SVT's the front springs are the same. Rear springs on the Ls V6 MTX and SVT are the same, rear springs on the SE V6 MTX and ATX are the same.
The mailing list archives are down right now, but check tomrrow or the next day, and look at this message . It explains what I just summarized above, showing codes and such for the springs.
Tarzann Offline OP
eek I think I'm more confused than when I started! confused
From what I can see, I have the same front springs as an SVT, (Code NYHN BTW) and no one is sure yet on the rear, though it seems they might be the same. So a set of used SVT springs would likely not be any improvement for me.
Thanks everyone!
Dave
98.5 SE/sport/MTX
Mobil 1/K&N oil
Clarion 9255
Vifa/Adire drivers
F
F
SPR = ARCB for 98 Mystique LS v-6 ATX No tags on frt. My frt springs or the damping is soft. The rears ride nice but carring capacity is terrible in the rear.
Paul
svt springs drop a stock se 1" all around. Need a set w\low miles let me know.
18" enkei cdr9 w/ kumho 225/40/18
5% limo all around
alpine head unit
jl xr series door speaks
2 jl w3 w/ppi 2600 and 1 farad cap
b&m
clear head lights
dingless
