#391920 11/24/01 01:09 PM
ABNeg Offline OP
Is there a way to stiffen up the rear suspension w/out lowering the vehicle? I don't want to be a pseudo-snow plow in the winter.
It seems that most car manufacturers set up the rear suspension loads for two people in the FRONT seat. When passengers are added in the rear (sometimes 3 almost adults; yes, it happens!), the vehicle sags enough that night driving wakes the birds in the trees due to headlights being pointed upwards.
My "other vehicle" (rear drive, 4-door, medium-sized sedan) has a beefed-up rear suspension & has to be loaded quite a bit before any sag is noticeable & yes, the ride is a bit boucy but the handling is surprisingly good.
TIA for any replies! smile
Is the smoke alarm in your house also known as the "dinner bell"?
'99 Zetec VCT Daily Driver
Mild Air Filter Mod
Lee Offline
Well if your just wanting to Stiffen it up to prevent rear sag you might just want to get so stiffer rear springs and struts. I'm sure there would be someone out there that makes them.
Lee Cox
In life begins responsability...
Project Car
H
H
just get Koni adjustables- and set the rears to harder than normal.
'98 SVT #2253
Currently DEAD!
Cobra Paradise
Stiff struts will help with bounce, stiffer springs will help with sag.
Black '98.0 GL V6/MTX, tints, SVT airbox (sans fender boot), stock muffler replaced with spiral racing muffler, A6 side markers, Cougar 16" polished wheels w/ bald 205/50/16 Yoko A520's, Mobil 1 5W30, Castrol SATF/Ford FM tranny cocktail, 9005 high-beam bulbs all around, re-aimed stock foglights
E
E
early se rears will fit on your car they r stiffer then the svt springs,u could put svt springs up front to stiffen everything up or just stiffen the rears
97 gsxr lotsa good stuff 4 sale
95 talon tsi awd turbo loaded sold
95 se 2.5 mtx loaded (fragile handle with care)2 motors 3 trannies
custom y with hi flo cat,custom dynomax exhaust,upper cat mod
superchip,udp,bat\kkm,proflow maf,ford 9mm wires,svt throttle body,svt intake manifold ,custom kevlar clutch,16 pd. flywheel,svt motor mounts ,svt gauges,eibachs\h&r,omp strut brace,dark chrome 16" rials with 225/50 dunlops,cwazy amounts of audio
