Posts: 3,248 |
This was in nother post. Anybody experiencing too much oversteer - rear end getting loose with the Aussiebar? I have the bar but not yet installed awaiting feedback. So far, I have heard it improves autocross times and reduces understeer but I have also heard about lifting a wheel in the turn and do not want much tendency for the rear to come around on the steet. What do you think now that the bar has been on a while? Thanks.
1999 Amazon Green SVT Contour (#554/2760) Stock SVT Duratec V6 with: Intake- K&N filter/75mm MAF meter Exhaust- MSDS Y-pipe/Bassani catback Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter 179.2 FWHP at 6900 RPM
Posts: 2,906 |
The back end can come out but you gotta really throw it around a corner alot harder than most of us do or being going some insane speed around the corner. I have hit corners very hard and the oversteer is predictable and manageable.
Josh Aka Spectra SVT 02 Dark Highland Green F-150 XLT Mods: Gunrack and cowboy boots
Posts: 2,906 |
Ditto, no unexpected oversteer Just a beautifully neutral car...
Spattmobili®
Posts: 1,428 |
Okay, so my SVT already oversteers when I trail the brakes into a hard corner... this is gonna be fun!  ... Where's my check book when I need it?!?
Posts: 3,248 |
Thanks all, other input???
Posts: 265 |
I'll chime in.
Non-SVT's have a larger front sway bar. Even with the AussieBar installed, my Cougar still understeers like a pig. Believe it or not, I'm actually thinking of possibly swapping over the svt front bar at some point. I'll move the battery to the rear first and see if that helps any.
Dan Beggs 99 Cougar V6, loud
Posts: 3,934 |
I have heard that putting the Aussie bar on a Zetec tour can do it as well. I think that the bar will make driving a lot more fun. Right now it understeers too much for my taste.
· Jon Miconi
· 96 Contour Zetec ATX · 80 Ramcharger 360 ATX · 77 Ramcharger 440 ATX
Posts: 1,003 |
Um, no oversteer. But I have a 95 which has the big front bar. Love my Aussie bar.
Alex in Boulder, CO 95SE MTX 157hp 151tq for now...
Posts: 7,329 |
That back end still kicks out under heavy power off or if you throw it hard into a corner. It is just a lot more predictable and much more controllable.
Posts: 3,934 |
Originally posted by Bicycle019: Um, no oversteer. I have yet to install my Aussie Bar.
· Jon Miconi
