Posts: 401 |
this is about stupid, but my friend told me to ask this.... he's got his old civic hes putting a B16A1 into it, the motor looks about the same.... couldn't that dumb motor fit in the contour??????? just a stupid question
*fixed* 1998.5 Contour SE Zetec No Cat, SVT Dual Exhaust, 2 N1 Mufflers, IAT , Diablo Chip, Iceman Intake, Polished TB, "new tranny"
Various other crap, no more mods for a while, just moved.
17.391 @ 81.03 mph
1995 Honda Civic CX Hatchback
15.34 @ 91.67mph
stuff.
Posts: 417 |
I would say mating the engine and the tranny would be an issue. The only way that you could really do it is if you cut the whole front end off a civic and welded it on the Contour, then try to put the Contour body work back on.
99 Ford Contour SE Sport Manual V6 SVT front/ rear bumper /w Aussie grille Jet black Premier DEH-P740MP head unit matrix display, plays Mp3s!! 800 watt Kenwood amp 2 12" Polk Audio subs Blue "euro" headlights Eibach Pro-Kit springs 17" Enkei RS-5 White Indiglow gages
Posts: 7,329 |
Posts: 2,481 |
Why in the hell would you want to drop a Honda motor in a Contour?
99 Range Rover 4.6 HSE Mystery Car??????
Posts: 10 |
dude if you want to dump a honda motor into your contour then spend the money a get a j-spec and NSX motor
Eurolite clear side markers Eurolite Xenon bulbs Weapon-R cool air intake
Posts: 3,237 |
I think Honda motors rotate in the opposite direction to most, so you would be real fast in reverse ~130mph!
Posts: 3,223 |
The tranny is mounted opposite ours so it would work out!
-Andy
Posts: 4,899 |
Originally posted by mmarfan: The only way that you could really do it is if you cut the whole front end off a civic and welded it on the Contour, then try to put the Contour body work back on. Someone did that, I saw a pic around here somewhere. Pretty lame IMHO.
Posts: 233 |
what the point in doing that??????
dont get me wrong honda motors are awsome but there not that great for heavier cars....the venerable b 16 produces 160 hp and like 130 torque the stock v6 tours have 170 hp and 165 torque
so other then the fact that you could say that you put the motor in there is not point. the fact that the contours weigh on average around 300-600 lbs more then the hondas is where there advantage comes
also the aussie is correct in the fact that the motor does spin in the opposite direction then ours so it would produce tranny fitiment problems (new rsx does spin properly) however
-Y2K SVT- BORN 1/03/2000 NOW IF ONLY HAD MONEY TO MOD IT
Posts: 716 |
Originally posted by WannaBe-SVT: this is about stupid, but my friend told me to ask this.... he's got his old civic hes putting a B16A1 into it, the motor looks about the same.... couldn't that dumb motor fit in the contour??????? just a stupid question UHhh sell your Contour and get a Civic.. or BUY TERRY'S TURBO KIT.. Cheaper than trying to fabricate and shizzle for that dumb ass swap.. just a thought -Chris
Chris Hinds AIM:CJ111010 1998 Contour GL Duratec 5-Spd #565/???? 15.610 @ 89.62mph And I payed for it all myself
