Page 2 of 2 1 2
Yeah, you go Chris.
Check this out I wonder if it will fit our cars? Say it would just needs the top bar lengthened. Not sure how easy it would be to alter and if it would make the design weaker than it should be?
I would get it but I don't have any room back there, with my sub box.
only $99 looks like it would be a hell of alot stiffer than any other solution. laugh Plus it looks sweet!
Justin
1998 Black SVT
jcboeckl@unity.ncsu.edu
That was designed for a Cougar. Wait for Hightowers. I can't wait to see another thumb photo. laugh
If it's true that we are here to help others, then what exactly are the others here for?
I don't know what Chris has in the works but unless it's a weld-on mounting it's less than optimal. I've got a weld on rear STB in my car. The reason I did weld-on is from past experience with a bolt-on mount. In little to no time the bolt holes were oval shaped, and that was using a nylock and bolt fastener assembly. Using self-tapping screws is even worse. The metal it's being attached to is a very light gauge. Unless the attachment method is by weld, it will eventually tear out. Check out my bar on our website.
Technical Director/Co-Owner Performance Fords-check out our new throttle body service
95 SE with lots of custom 1 off mods. All design, fabrication and installation by owner.
Perhaps it is a new design that will not tear out and does not solely depend on bolts. Maybe I'm testing one right now so a product that does rip out will not hit the market. wink
Weld-on is cool and all... but I need one that can be removed if I ever need to move something big.
Stay tuned. Still being tested but it will remove.
OK. Somebody smarter than me (read, engineer) worked it out that these bars are actually under extension forces under hard cornering, not compression as is commonly believed. If that's the case, the self-tapping screw method seems worthless, and I don't know of any bolt-on method that would really handle the stress.
Trouble is, IIRC welding is prohibited in STS. Hmmm. Frustrating.
"Function before fashion."
'96 Contour SE
O
O
WHAT ABOUT THE SHO ONES? ARE THEY CRAP? I WAS LOOKING AT GETTING BOTH THE FRONT AND REAR STB. WHAT ABOUT CHRIS HIGHTOWER'S STB? IS THERE A FRONT AND REAR AND HOW LONG TILL ITS READY?
THANKS,
MIKE
'98 SVT CONTOUR BLACK W/MIDNIGHT BLUE INT. CUSTOM GRILL, 17" ASA CHROMIES(LISCENCED BY BBS)ON BFG COMP T/A ZR'S, K&N FILTER, PIONEER HEAD UNIT, CLARION FACTORY REPLACEMENTS, CUSTOM KICK PANELS W/ORION CONCEPT COMPONENTS, ORION AMP, 12'S, DYNAMAT, AND NITROUS EXPRESS (THE ****)!!
FUTURE MODS.- NEONS, COLD AIR INTAKE, EXHAUST, MSD IGN., ANY THING FOR MORE POWER, LCD SCREEN, DVD ,AUTO PC, MORE AMPS, AND THE LIST GOES ON! smile
Page 2 of 2 1 2
