I have checked this out on a couple of Contours from the Atlanta area 99SVTGUY and Tony it's a perfect fit for the Contour also.
I have a group deal in place for NECO and Contour.org members. It comes with complest instructions and bolts on not just self-tapping screws.
Bradleycougar
Check It Out!
How does it use bolts, looks like a nice fit.
Good find..
Later,
Justin
Justin
1998 Black SVT
jcboeckl@unity.ncsu.edu
It uses 8mm bolts that are pulled up from inside the strut tower. Don't worry nothing has to be removed to install and it comes with detailed instructions (with pictures on how to pull the bolts up from inside the strut tower. I believe it would take a novice about an hour to install. I have installed mine in about 30 minutes when we develoved the instructions over at Random Technology. Thank you,
Bradleycougar
I
I
Looks good but whats the cost.
This strut tower brace can be purchased for $149.00 plus shipping.
If it's true that we are here to help others, then what exactly are the others here for?
H
H
hey keyser dont worry i havnt forgot about it yet- just a lot of work with little time
'98 SVT #2253
Currently DEAD!
Cobra Paradise
Doesn't look like I can get the cap off the brake fluid reservoir for my annual brake/clutch bleeding exercise. It also looks incredibly similiar to (the same as?) the Sparco unit. I'd also like to know how to get bolts around the upper/inner strut mount/perch. Personally, I wouldn't buy it without fitting it first on my car due to the above noted issues. Besides, our cars need a rear STB much more than a front one.
Technical Director/Co-Owner Performance Fords-check out our new throttle body service
95 SE with lots of custom 1 off mods. All design, fabrication and installation by owner.
I want a REAR STB!!! Bad!
I agree. The rear is far more important and effective than the front.
2000 SVT #674 - Check it out!
Administrator
Administrator
One is in the works. Stay tuned.
-Chris Hightower-
(Oo.«xx».oO)
o xxxxxxxxx o
