Page 2 of 2 1 2
#39116 02/23/02 04:08 PM
The Performance fords Y-pipe is supposed to give you the performance gains, without any drone that everyone's getting with aftermarket catback exhuasts. No dyno results yet, still in prototype testing. I just received and email from Performance fords and it's in they Y-pipe groupbuy post (linked in the post above).
1996 Contour SE Red V6 MTX
1995 Contour LX Champaign V6 ATX (my wife's beater)
SuperChip | KKM Intake | Ford Motorsport 9mm Wires | Bosch +4's | Mobil 1 | No Resonator | Knauberized Doors | JSP Custom Wing | Re-wired Fogs | Red Painted Calipers | 98+ Sail Panels | Vuncannon Alarm | Lighted Moonroof Switch | Pioneer Head-unit | Pioneer 6x8's
#39117 02/24/02 12:17 AM
2
2
I realize that, thanks!
Its a bird, its a plane...wait!..W.T.F.W.T..?
#1800 of 2150
#39118 02/24/02 07:40 PM
F
F
2000 greensvt.. If you don;t have a high flow cat-back exhaust setup I highly recommend you get one before the y-pipe. The y-pipe will creat so much more airflow that backpressure will increase beyond stock levels. Second, remember that the y-pipe (sho) ends up with a 2.5" dia end, so make sure you match it or have a exhaust shop cut out the flange and turn it into a slip on so that airflow will not be impeded from a 2.5" to 2.25" reduction. It is another reason I got the Brullen so that I could have the 2.5" to match.
Eric
First I would like to congratulate my 2002 "The Perfect Storm" undefeated National Champions MIAMI HURRICANES*1999 Ford Contour SVT #206 00 SVT motor with Return fuel*Black-Tan*Cold Air Intake with 6" S&B Funnel Ram*Sho-shop off road y*Brullen Cat-Back 3.5" slant tips no res*Unorthodox racing crank pulley*Lotec Guage pod with Air/Fuel, Oil Pressure and Voltage*17" Image Tuners*215/40 Falken Ziex's*
B/M Short Shifter*Nokya 9006/9005 80w/100w Xenon's*JSP wing*BNM White Faced HVAC*Custom svt emblemed rear*Bosch +4's*H/R springs*Euro Sidemarkers.
Eric@ritterpenusa.com Centerforce Dual Friction Clutch and Fidanza Flywheel.
#39119 02/24/02 07:56 PM
2
2
I got the bassani cat back! it just came yesterday!
#1800 of 2150
#39120 02/24/02 08:28 PM
F
F
Cool...the bassani is 2.25..the y pipe is 2.5..It still does mate together but your going to have a diameter difference betweent the y and bassani..so it really would not be "optimized Flow" I know it would be hard but I would cut both flanges out.(sho/Bassani) and have an exhaust shop weld a reduction sleave between the two to get optimum flow.. laugh
Eric
#39121 02/24/02 08:31 PM
2
2
actually, that sounds like a good idea! but do u really think it would hurt performance if i didn't do it??? I couldn't see it making a huge difference!
#1800 of 2150
#39122 02/24/02 08:38 PM
F
F
I know..I'm just a stickler for perfection.. I would say about a 2-3hp loss top end..
Eric
#39123 02/24/02 08:40 PM
F
F
Also get a y-pipe with a cat...heard the Bassani and off road -y droanes like a Biaaatch..sounds like pure ARSE!!!
Eric
#39124 02/24/02 08:54 PM
2
2
ya, I am defently getting the one with the high flow cat!
#1800 of 2150
Page 2 of 2 1 2
