#391046 09/18/01 08:56 PM
1
1314 Offline OP
1
i called tirerack about Konis and the guy said they weren't adjustable (i forgot to ask for Luke). Isn't he wrong? Anyway, if they are, how easy is it to adjust them once they are on? Does the car need to be jacked up? And how much of a difference is felt from, lets say, the lowest setting to the highest setting? Thanks for any answers i get.
99 SVT Contour
02 Protege5
#391047 09/18/01 08:59 PM
Try Mysticali, he has them on his Tour.
All you do is open the hood and put a (removable) knob on and turn it to which ever setting desired.
Silver 98 SVT Contour E0
#4124 (Currently on Life Support)
Built 11/97 Bought 1/98
Eibach Pro Kit \ Koni \ Niche Pultec 17"x7.5 \ Yokohama Parada 215/17/40 \ Shaved Wheel wells / Brembo-KVR Cross Drilled Rotors / KVR Carbon Fibre Brake Pads / Aeroquip SS Brake Lines \ 21mm Rear Progress Tech. (Powder Coated Black) \ Superchips Auto Meter Pro Shift Light \ Extrude Honed \ Stripped Resonater Street Scene Free Flow Exhaust \ Injen Technology Prototype CAI \ Weapon R filter \ Hose Techniques Red Kit \ Folia Tec Red Caliper Paint \ MOMO (shift knob, pedals, seat belt pads) \ Clarion, Sounstream, Kicker \ Optima Red Top Battery \ SVT Emblem Mods
Jet Hot Coatings (25-30% Cooler) on Upper Intake Manifold, Sho Shop Y-Pipe, Cat, and CAI
"Come Out...Come Out Where Ever You Are"
http://www.geocities.com/speeddemons19
#391048 09/18/01 09:11 PM
Heard the rears are somewhat a PITA. Can't fit the knob back there very well or something like that. Not a good enough reason to pass the Koni's up...still by far the best strut out there for us.
Ryan
Latest Mod: Mirko Splitter
#391049 09/18/01 09:36 PM
Fronts are VERY easy to adjust, rears can be tricky. What I did was to buy a cheap 1/4 ratchet (smallest one you can find) then use a 3/8 or so socket into which I glued the inside of the plastic knob that Koni provides. It means you trash one of the adjusting knobs but it works really well to reach the top of the rear struts.
There is definatley a difference between stock and softest koni setting and between soft and firm. Try it, you'll like it. wink
99 Black&Tan SVT #308 - For sale
Borla Catback, K&N
Blaupunkt
'01 Audi S4 Avant yeeehaa!!
91 Audi Coupe Quattro- For sale
68 Mustang Convertible (summer fun)
#391050 09/18/01 10:06 PM
Yeah i cant wait to get some of my own.
I tried clicking my heals, but no luck yet.
Ill keep you guys posted if it works.
Email me for a How-to? :p
#391051 09/18/01 11:46 PM
I
I
Ride dampness is adjustable, but the struts themselves aren't.
I have the Koni and Ground Control setup and words cant explains how my car handles now.
Can you say 110 mph through extreme curvy roads without the rear breaking loose!
99 Range Rover 4.6 HSE
Mystery Car??????
#391052 09/19/01 01:17 AM
1
1314 Offline OP
1
Thanks guys. i hope to get them very soon (before the end of the month) and i just wanted some basic information. By the way, what is the life span supposed to be on them?
99 SVT Contour
02 Protege5
#391053 09/19/01 02:53 PM
Funny, but on my 95 I have no trouble getting the adjusting knob on the rear struts. Although, come to think of it the 95 SE has a unique upper strut mount per Ford p/n's.
Technical Director/Co-Owner Performance Fords-check out our new throttle body service
95 SE with lots of custom 1 off mods. All design, fabrication and installation by owner.
#391054 09/19/01 09:17 PM
Ahhh drool :p I want some koni's
Mike | 98 Silver CSVT
#391055 09/20/01 01:04 AM
Q
Q
Try using a grinding wheel to decrease the diameter of one of the adjusting knobs. After a bit of modification, it fits in there just fine. I also made two marks on opposite sides of that knob (a + and a - mark) so when you are adjusting the struts, you know how many turns you have made. My .02
98.5 SVT ~ diamond white metallic custom DuPount paint ~ shaved antenna, trunk key hole, and ding strips ~ roof mounted antenna ~ 20% tint ~ clear corners (front) ~ Audi A4 sidemarkers ~ 17" Mille Mille Evo 5 wheels with Yokahama Parada Spec-2 tires ~ Koni adj. struts ~ Eibach springs ~ SMA rear strut tower brace (front no longer fits ~ Powerstop cross-drilled rotors ~ Mintex A/F pads ~ ploy bushings including motor mount insert ~ 3L conversion ~ full custom intake ~ custom Cardoc exhaust ~ gutted precats ~ 24lb injectors ~ 3L upper and lower intakes ~ Rear dome light mod ~ glovebox light mod ~ lighted moon-roof switch mod ~ fog light mod ~ Autometer shift light ~ FCO indiglow guages ~ body color interior bits ~ some custom sound
Administrator www.fordcontour.org
