Posts: 1,732 |
Originally posted by hmouta: whats the difference between strut brace and sway bar. If the strut brace goes in the trunk, where does the sway bar go? rear sway bar goes under the car right near the gas tank. try www.spmotorsports.com to look up what they say about various mods.
- Pete - 00 SVT SF/MB - 1522/2150 - DOB 1/12/00 ------------------------------ 92% says your group-NOT HOT 85% says your either wrong or BLIND Blackhawk Down did NOT suck you know who you are.....
Posts: 1,050 |
Here is a pic of our prototype unit: http://www.performancefords.com/products/proto/proto_stbr.html You could try and fabricate something similar. You have several options on how you may want to design and attach it.
alessandro PERFORMANCE FORDS- Unique parts for the contique and cougar SVT Owners Association - Toronto Chapter
SilVer_bulleT@rogers.com 1999 Silver SVT
Funnel Ram, PF Maf Adapter, Magnecore, Brullen Exhaust, Brullen Y-Pipe, O.Z. Supperleggera...MORE toys waiting to be installed... 177hp, 155lb-ft
Posts: 463 |
What kind of bar material should I use? I check out Home Depot and all they have is steel galvanized Conduit pipes. I think they'll work, but they're so heavy. Where can I get some aluminum bars or lighter gauge pipes?
Posts: 661 |
Our brace is made from 1 inch heavy wall ERW tube. For maximum strength you can go to a DOM tube, but it's really overkill. Forget Home Depot and find a proper materials/metal supplier. Then the fun begins as the fabrication/fitting is the difficult part! For maximum strength your brace should be welded in place as mine is.
Technical Director/Co-Owner Performance Fords-check out our new throttle body service 95 SE with lots of custom 1 off mods. All design, fabrication and installation by owner.
Posts: 463 |
Can the Performance Fords' rear strut brace be ordered without the additional "diagonal" bar? I need to be able to use the trunk and the fold down rear seats if the item I'm loading is too long. Or I might want to put a subwoofer box right against the rear seats.
Posts: 661 |
Yes it can be a 2 point. Give me the details - weld in or bolt in? Welding is much better as it is much stronger than bolting. It's cheaper for us to fabricate too.
Posts: 463 |
I would prefer bolt-in, cause I don't have access to a welder. Ane also, I want to be able to remove it... let's say, when I'm moving big items...ie, furnitures, boxes.
Posts: 2,481 |
Just order supplies from www.mcmaster-carr.com 1-2 day shipping. Thank me later.
99 Range Rover 4.6 HSE Mystery Car??????
Posts: 355 |
at http://www.mcmaster.com/ I cant find anything cheaper than 130! what do you use?
Posts: 463 |
Icey... can you list the parts # that you've used for your bar. Thanks alot.
