Posts: 517 |
Does anyone know if you can use the Leda adjustable struts with Ground control coilovers? I hear the with the stock or Koni struts that the spring perch has to be cut off, but it looks like the Leda don't have a spring perch. Any info on stuts to use with ground controls would be a help.
2000 SVT (silver) #1529 of 2150 ------------------- yeah...its modded
Posts: 3,598 |
The Leda adjustable struts already come with their own style coil-over sleeves attached to them... the ground control kit is un-needed.
\'94 Cobra #4963/5009, black on black, not quite stock Formerly owned a black '00 SVT, #1972 Join the SVTOA! RIP - Ray "Old Fart Emeritus" McNairy
Posts: 517 |
do you know how much the Leda suspension kit costs? and where to get it?
and since it has the sleeve is both the strut and the coilover both adjustable like having the Koni's and the Groundcontrol or does it have just one adjustment
Posts: 3,598 |
The kit is something like $1500+ (I think). The strut is fully adjustable, with 24 positions. The coil-over setup is (naturally) height adjustable. The ride is rather harsh, IIRC. The Koni SA with Ground Control combo is much more streetable, and slightly cheeper. Unless you plan on road-racing all the time, it could be considered overkill compared to the Koni/GC combo.
Posts: 517 |
i'm not road racing, but i wanted a complete system...I heard its a pain in the ass to cut the spring perch off the Koni for the coilovers, and that someshops won't do it. Also heard that people have to get the coilover welded onto the strut? Getting the complete system from Leda might be a better deal, after all the labor on the Koni's and groundcontrols
Do you know of a place that sells the Leda kit?
Posts: 3,598 |
Check with Leda , but I don't remember what the US distributors are at the moment.
Posts: 67 |
I have the ground-control/ koni setup. The easiest part is cutting the perch off and you don't weld it on. The strut is steel and the GC sleeve is aluminum, so you can't weld it. Through two group buys I got the whole setup for under 875. I'm 20 and no great mechanic and I did it all myself. Took about 8 hrs.
96' LX (de-badged,konis,ground controls,injen intake,hose techniques kit,gauge pod,phantom gauges) more soon...
Posts: 517 |
thanks for the info moonlight, i might get the Koni's and the groundcontrols if its easy, but i have to find someone to put them on too.
Posts: 3,331 |
Showtime, I will be switching to GC very soon. Like right after NOPI. StreetConcepts has a shop that will do them for $200. I am jumping on that one.
99' SVT 86' Toyota Pickup Beater - Tha Daily Driver
Posts: 175 |
If you get the koni's do you have to have the g/c's? If I got ebiachs and konis would I need them? thanks---chris
