Posts: 517 |
Does anyone know if you can use the Leda adjustable struts with Ground control coilovers? I hear the with the stock or Koni struts that the spring perch has to be cut off, but it looks like the Leda don't have a spring perch. Any info on stuts to use with ground controls would be a help.
2000 SVT (silver) #1529 of 2150 ------------------- yeah...its modded
Posts: 3,598 |
The Leda adjustable struts already come with their own style coil-over sleeves attached to them... the ground control kit is un-needed.
\'94 Cobra #4963/5009, black on black, not quite stock Formerly owned a black '00 SVT, #1972 Join the SVTOA! RIP - Ray "Old Fart Emeritus" McNairy
Posts: 517 |
do you know how much the Leda suspension kit costs? and where to get it?
and since it has the sleeve is both the strut and the coilover both adjustable like having the Koni's and the Groundcontrol or does it have just one adjustment
Posts: 3,598 |
The kit is something like $1500+ (I think). The strut is fully adjustable, with 24 positions. The coil-over setup is (naturally) height adjustable. The ride is rather harsh, IIRC. The Koni SA with Ground Control combo is much more streetable, and slightly cheeper. Unless you plan on road-racing all the time, it could be considered overkill compared to the Koni/GC combo.
Posts: 517 |
i'm not road racing, but i wanted a complete system...I heard its a pain in the ass to cut the spring perch off the Koni for the coilovers, and that someshops won't do it. Also heard that people have to get the coilover welded onto the strut? Getting the complete system from Leda might be a better deal, after all the labor on the Koni's and groundcontrols
Do you know of a place that sells the Leda kit?
Posts: 3,598 |
Check with Leda , but I don't remember what the US distributors are at the moment.
Posts: 67 |
I have the ground-control/ koni setup. The easiest part is cutting the perch off and you don't weld it on. The strut is steel and the GC sleeve is aluminum, so you can't weld it. Through two group buys I got the whole setup for under 875. I'm 20 and no great mechanic and I did it all myself. Took about 8 hrs.
96' LX (de-badged,konis,ground controls,injen intake,hose techniques kit,gauge pod,phantom gauges) more soon...
Posts: 517 |
thanks for the info moonlight, i might get the Koni's and the groundcontrols if its easy, but i have to find someone to put them on too.
Posts: 3,331 |
Showtime, I will be switching to GC very soon. Like right after NOPI. StreetConcepts has a shop that will do them for $200. I am jumping on that one.
99' SVT 86' Toyota Pickup Beater - Tha Daily Driver
Posts: 175 |
If you get the koni's do you have to have the g/c's? If I got ebiachs and konis would I need them? thanks---chris
Posts: 1,428 |
skatrcj: Ground Control makes a height adjustable spring setup that fits over our struts. If you have standard Eibach springs they are just sitting on the Koni's perch and your car is happy. ![wink wink](/ubbthreads/images/graemlins/default/wink.gif) If you want to drop your ride real low and be able to raise it back up sometimes you would use the GC coilovers on your Konis instead of your Eibach springs. Hope this helps!
Posts: 2,066 |
Would it be worth it to get the ground controls w/ the stock SVT struts or should I just wait until my suspension wears out and get the Koni/GC combo all at once. I'm sure the second one would be better, but I don't have a whole lot of money (still in college) and I wonder if it would be worth it to wait and get both at the sametime or one at a time?
Thanks, Justin
Posts: 1,428 |
As with any other spring install, if you buy only the GC kit and install it on stock struts you'll have to do the entire process a 2nd time when you want thos Konis in there. This is what I did because I didn't know if I was gonna keep the GCs and didn't want to ruin a brand new set of Konis. Now that I'm happy with the GC kit I have to go back and install it on Konis... Again I have access to lift and air tools so everything's easier. Then there's the problem of bounciness. Even good SVT shocks don't have the rebound damping necessary to control the ERS springs in the GC kit. This will show mostly at highway speeds if you hit a swoopy dip in the road it'll take the car a 2nd bounce before it takes a set. This is NOT a really sought after behaviour and the only way to avoid it is with a stiffer shock valving (aka Konis or other). I've been living with it for a while though and although I swear at it every time I can't help but smile whenever I step out of my car and take a good look at it ![laugh laugh](/ubbthreads/images/graemlins/default/laugh.gif) My next upgrade is Konis with sway bars, strut bars and better bushings all around.
Posts: 1,428 |
Oh, jcboeckl you have mail!
Posts: 227 |
Silversvt- Did you get to specify what spring rate you wanted or did they just give you a "contour svt" package?
ND SVT 2000 SVT (Black/Midnight Blue)
Posts: 2,066 |
Thanks SilverSVT a ton,
I think I am going to work on saving for a Borla/ypipe first then I will work on the suspension. This will give me more time on my stock struts and more time to save money.
Oh and THANKS FOR THE EMAIL!! Thanks, Justin
Posts: 1,428 |
ND SVT: Naah you don't get to pick and choose... I'm actually looking for the specs of their kit, I'd really like to know what rates I got. I'll call them on that some day, I think it's the exact same package for all V6 Tours and Cougars as well. No "SVT special" stuff here... As soon as I figure my spring rates I'm going to order a set of 4 softer springs for winter from a race supply store.
jcboeckl: Glad I could help! Have fun...
Posts: 227 |
Originally posted by Silversvt: ...I'm actually looking for the specs of their kit, I'd really like to know what rates I got... If the box or a spring has a part number on it you can look it up in one of these tables on their website: 2.25" inside diameter , 2.5" inside diameter Let us know if you find out so that we can order a second set also. Thanks for the info!
Posts: 1,428 |
They do have a number on them... I'll have the car up on jacks next week to install new pieces and work on my brakes so I'll jot down the numbers then and post back in this forum.
Posts: 93 |
Acconding to Terry Haines If we want confortable ride with the ground control but with track capabilities. "We need and a harder valving strut set up and a softer spring. This will keep the ride softer on the street and adjustable for thr track."
"You can turn a engineer into a sale man but, you can not turn a sale man into an engineer" "I have walk to the valley of Honda and death for that I should not fear no V-tech"
99 cougar,SVT manifold convertion, Tranny upgrade by Haines Motor sports (Quaife lds, Fidanza flywheel, and Clutch Master Stage 3 clutch) 18" Axis Se7ends,GC coiovers,sho sho Y pipe,Wilwood4 piston brake kit
