Posts: 583 |
I found the hex on the rear head to install the sender.. my question.. it loosens up counter clockwise right? That thing in a pain to take out..it won;t budge..am I missing something.
Thanks in advance Eric
First I would like to congratulate my 2002 "The Perfect Storm" undefeated National Champions MIAMI HURRICANES*1999 Ford Contour SVT #206 00 SVT motor with Return fuel*Black-Tan*Cold Air Intake with 6" S&B Funnel Ram*Sho-shop off road y*Brullen Cat-Back 3.5" slant tips no res*Unorthodox racing crank pulley*Lotec Guage pod with Air/Fuel, Oil Pressure and Voltage*17" Image Tuners*215/40 Falken Ziex's* B/M Short Shifter*Nokya 9006/9005 80w/100w Xenon's*JSP wing*BNM White Faced HVAC*Custom svt emblemed rear*Bosch +4's*H/R springs*Euro Sidemarkers. Eric@ritterpenusa.com Centerforce Dual Friction Clutch and Fidanza Flywheel.
Posts: 30 |
correct. Turn bolt counter clockwise to loosen. When I did mine I used a 1" extension a swivel then a 3" extension. If you don't have a 1/4" hex socket go buy one. it makes the job a lot easier.
98 svt #3967/6535 BOD 10/13/97 itg air filter air inlet pipe south country strut tower brace A pillar gauge pod w/autometer Volts, Oil Pressure. and A/F Ratio Replaced resonator w/Dynomax Bullet
Posts: 923 |
Does anyone have a picture of this location?
Posts: 583 |
Thanks IDRVFAST... I knew I could count on someone...
Eric
Posts: 156 |
Hey hey are you guys talking bout the mechanical oil pressure gauge, if so were in the hell did you guys install the sender? Also how hard was it to install? Just got mine today, going throught the directions, kind of confusing.
Chris Reid 99 Black SVT #6330
Posts: 5,805 |
Behind the a/c compressor to the left of the existing sender unit is another hex plug.This goes straight to the main oil gallery,thats where we put ours....
Posts: 923 |
Thanks terry, that sounds a little easier.
Posts: 251 |
What location do you guys use to get the wires from the passenger compartment to the engine bay????
Curtis Dead 98 Black SVT 92K
Posts: 5,805 |
R/H rear of firewall,between brake booster & cruse module,remove the felt insulation...a hole!.Remove the wiper arms & top plastic covers...feed wire thru....
Posts: 251 |
Excellent!!! Thanks, Terry. That should be easy with a gaping hole in the engine bay. Let the games begin!!!
