Posts: 433 |
Hey I would like to get a look at your set up some time soon since I work down the street from you. Are you going to the NY meet this Saturday at teh Palisades Center? Hope to see you there.
Silver Frost 2000 SVT #1443 of 2150 Mirror Tint/ Momo shift knob/ Kurtz Kustom pedals Ventshield raingaurds, moonroof and hood bug deflectors True Rev Induction Kit/ BAT Air Inlet Pipe Philips HID kit/ PIAA superwhite fogs/ Chrome Gas Bonnet Lifters Top of line Alpine system( NVE-N851A, DVA-5205, IVA-C800, TUE-T011A, KCE-150V, CHA-S624, PRA-H400), PPI (PC 4100, PC 2150,PRO 10's), Image Dynamics CD2 Comp MH and IDQ-62. Motorola Timeport HF car kit Looking to increase performance! http://photos.yahoo.com/hpick1 Future Mods waiting to be put on: Lotek Guage Pod w/ volt, a/f ratio, and oil pressue. Blue neon undercar kit Aussie Bar w/ upgraded backing plate Bullitt Fuel Door Magnacore Wires Ground Control Kit w/ Koni Struts
Posts: 1,681 |
hey shaggy those gauges that you are going to be mounting in the cluster look bad as hell. great job, you do any side work? hehehee
Posts: 1,428 |
So, how does that Accusump really work... Do you need to flip a switch to pre-oil before starting the car up? Can your g/f still drive it or is it gonna run dry / explode if someone less knowledgeable has to drive it?
Posts: 1,028 |
Originally posted by Silversvt: So, how does that Accusump really work... Do you need to flip a switch to pre-oil before starting the car up? Can your g/f still drive it or is it gonna run dry / explode if someone less knowledgeable has to drive it? The best part of the AccuSump system is that Terry installed an electronic switch. The car is on, its ready to go, all automatically. I know I would forget to open a manual valve. Simple yet effective!
Chris NJ 98.5 SVT Silver Frost w/Frankentrans carsla AT optonline DOT net
Posts: 1,028 |
Originally posted by fst4dr: Sweet! Any way you could get a good pic of the electric W/P setup. Maybe remove the front plastic cover? Just want to see how that is set up. Looks great Simon, I would like to get you pix, but the damn thing is burined by the lube manifold. Plus, I still don't have a digital camera.  I'll see what I can do though, it may take me some time.
Posts: 3,562 |
The install looks a little rough around the edges if you know what I mean. Was this the first install Terry did of all of this stuff? Needs a little more work in the aesthetics department, i.e, running hoses, ty-wraps not organized, etc. As long as it all works once he gets better tubes, will it be cleaned up? That trans manifold have a bracket that goes on it? Hummmmmm, looks like Mario and Luigi's plumbing nightmare!
Brad Noon '99 SE MTX 3 point oh my God H.O. 179HP/178TQ BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!bnmotorsports@msn.com
Posts: 1,028 |
Originally posted by bnoon: The install looks a little rough around the edges if you know what I mean. Was this the first install Terry did of all of this stuff? Needs a little more work in the aesthetics department, i.e, running hoses, ty-wraps not organized, etc. As long as it all works once he gets better tubes, will it be cleaned up? That trans manifold have a bracket that goes on it? Hummmmmm, looks like Mario and Luigi's plumbing nightmare! Yeah, my car is the first car he had with all of this stuff installed. I too am not happy with all of that mess, but little by Terry and I working on cleaning it up. I mean, he is going to redesign the manifold and mount it further down and out of the way. I will be changing the hoses to all Aeroquip hoses with the proper fittings to make it neater and have hopefully have shorter runs of pipe. I am also going to repaint the silver where it flaked off the chasis, where the battery tray used to be. But, my main concern so far is to get everything working properly and quiety. The tranny lube pump is loud! It is mounted on rubber isolaters, but still vibrates like no other. I am going to remount the pump (if I can get my paws up there) and use bigger isolaters and box up the pump. Of course, I don't want to cover the pump's vents. This is almost becoming a R&D project here. Thanks for the responses, keep them coming!
Posts: 5,805 |
Sorry your not happy Chris,pity.Your new hoses went out today.
Posts: 1,296 |
So basicaly you paid $4100 to keep everything from braking? Why?
Tim
Posts: 1,028 |
Originally posted by [Corbett]: So basicaly you paid $4100 to keep everything from braking? Why? Well simply put, I plan on keeping the car a long time. I do plan to eventually run CH's turbo and the stronger parts are, the longer they last.
