codeo Offline OP
I'm new so I was wondering what all is change between the normal 2.5 duratec and the svt high output.I'm pretty sure that the headers are differant but what else? confused
91' civic sedan.iceman CAI
Administrator
Administrator
Well, a lot, actually. I would recommend using the search function... wink
The differences are:
-upper and lower intakes extrude honed/larger ports
-extrude honed heads
-hotter camshafts
-more advanced spark curve/tuned for 91 octane
-19lb injectors vs 16.7lb
-higher compression pistons
-conical air filter/air box/air tube
-larger throttle body
-slight differences in the exhaust manifolds (a little better flow)
-2.25" quasi-dual exhaust vs. single 2" pipe
Probably missed something, but that's a pretty good start...
-Lance
Lance Kinley
CEG Webmaster
95SE, "Official CEG Beater"
Quaife, SVT parts, ST200 wheels, SS Y-pipe
I perceive you to be a stand-up, rational individual...
codeo Offline OP
thanx alot, didn't know about the search function
1
1
I sicked your brother on you, smile
Thnx Tim! We're gonna have to have a 'talk' about behavior on this site. wink
codeo Offline OP
Oh great its time for "the talk".
Other stuff on SVT:
- Flywheel is 12 Lbs. lighter
- Crank is hand selected
- Extra oil cooling
- Different motor mounts maybe ??
Scott
1
1
Originally posted by tw0wheelin:
Other stuff on SVT:
- Extra oil cooling
Actually thats:
- Flywheel is 2 Lbs. lighter
(19 vs 21 IIRC)
codeo Offline OP
thanx didn't realize there are that many differances.it seems like the block is the only thing that stayed the same. eek
Hand selected crank? Anyone care to elaborate?
Dan Parmelee
1999 Acura Integra SiR-G coupe
"I heard Affleck was the bomb in Phantoms"
"Word, bitch! Phantoms like a muhfuka"
