Mine should show up in a few days. I think you have to change the throttle cable and the cable bracket. Also may need to port match the se upper manifold to the svt tb.
I'm getting the uppers, lowers (with injectors), and tb all from the same guy, so i man forgo installing the svt tb on the se manifold all together.
I'll throw up some pics if do install it on the se uppers.
98 SE BAT Big Brake Kit "C", Throttle Hang Fix, B&M Shifter, Lightly Cracked Secondaries, BAT Euro Handling Kit, 20% tint, Removed Ding Strips, ES Motor Mount Inserts, Borla CatBack, Apexi SAFC, HighTower Rear Brace, BAT 19mm rear bar, MSDS Headers & Y, AFE 20-35008 filter, ClutchMasters Stage 1, Fidanza FlyWheel, SVT T.B. ====OnOrder==== svt uppers and lowers,
