#385901 03/20/02 02:39 AM
SVT19 Offline OP
Some guy that my friend knows thinks that his Probe GT has a Duratec Engine in it. He also thinks it's the same engine that is in a Contour SVT. I know its not the same engine that's in a SVT Contour and also last time I checked it's the same engine that is in a Mazda MX6. Can someone tell me if I'm right or wrong
'98 E0 Black SVT Contour
BAT Air Inlet Pipe w/ITG Filter
#385902 03/20/02 01:08 PM
I think you are correct. The probe has been based on the mx-6 platform for a while, so it should have the same driveline as the mx-6. From what i can find, the pgt and mx-6 have 2.5l v6 from mazda, but it does look a lot like the duratech with different intake manafold on it. I think this warrnts further investigation, as there are a lot of parts out there for the probe and mx-6
Also the escort and the protege share, or used to share, the same underpinnings. But i think the protege borowed the dirvetrain from the escort.
98 SE
BAT Big Brake Kit "C", Throttle Hang Fix, B&M Shifter, Lightly Cracked Secondaries, BAT Euro Handling Kit, 20% tint, Removed Ding Strips, ES Motor Mount Inserts, Borla CatBack, Apexi SAFC, HighTower Rear Brace, BAT 19mm rear bar, MSDS Headers & Y, AFE 20-35008 filter, ClutchMasters Stage 1, Fidanza FlyWheel, SVT T.B.
====OnOrder====
svt uppers and lowers,
Moderated by  Lee_dup2, unisys12
