Page 6 of 13 1 2 4 5 6 7 8 12 13
Wasn't sure, so I didn't quote whom did the testing. However, if true, this is not a good thing.... My experience locally is that there is great demand for wrecker Duratec motors. Always oiling failure. What does that tell you?
Technical Director/Co-Owner Performance Fords-check out our new throttle body service
95 SE with lots of custom 1 off mods. All design, fabrication and installation by owner.
Bradness, how do you know they are oiling failures, what confirms this when you tear them down? Can a spun bearing from crank whip look the same?
I have been looking at all these reports for a year as best I can. I think some cases certainly sound like oil related - happened during a turn, oil light came on, etc. Several of these reported low oil in pan but not all. But greater than half occured with no hard right turn (some were hard left turn) or high RPM invoked. Just reportedly cruising. Hard to say how accurate the reporting is but many of these cases do not sound oil related but I think alot of people, including dealers ASSUME its oil related. I personally think we have good evidence that harmonics is playing a role here - enough that Ford actually changed the damper.
Would like to know more about the Roush testing ie. 1/4 quart oil in pan at 5000 RPM. I assume this is at SUSTAINED 5000 RPM. The heads may then be full of oil so that at higher RPM there is still the same amount in the pan?? So, how much oil at 7000 RPM. How much oil during brief spins to 7000 RPM? I suspect that typical brief runs through the revs are OK but sustained RPM >5000 PLUS a hard right turn (to get rid of that little oil around the pickup) = problems. I bet that for all but extreme roadrace duty, the extra 1/2 quart in the pan solves the problem as Roush suggested. But I would LOVE someone from Roush to comment...
And thanks for hooking me up with the dual mode Aussie..
1999 Amazon Green SVT Contour (#554/2760)
Stock SVT Duratec V6 with:
Intake- K&N filter/75mm MAF meter
Exhaust- MSDS Y-pipe/Bassani catback
Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter
179.2 FWHP at 6900 RPM
I'll second that...
2000 SVT #674 - Check it out!
Um...so is this the dual mode damper from the cougar? I thought they were perfectly ok to use on our cars. And if it's a stock part off the cougar, why is it so hard to get?
1999 Silver Frost SVT
#609 of 2760
Born on 12/3/98
KKM Intake
Removed Resonator
35% Window Tint all around
Tinted Tail Lights
ElKy Mesh Grilles
HID
Dyno'ed at 175.3HP/155.5TQ
I think you will find thet the dual mode damper is a stoc Ford part for 2000+ Mondeo V6's not Cougars or Contours....
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
any part numbers on them? I might be able to get more when I go to Istanbul
can somebody please take some pictures of it and post them =? please please frown
Pics soon.... wink
V6 MTX
thanks laugh
Originally posted by DemonSVT:
I'll second that...
I'll second the second of that, Thanks Staz!!!
laugh wink
Performance Xpress Racing
Silverbulitt@msn.com
Our websit www.PXRacing.com is coming soon!!
We carry Contour/Cougar parts for the 2.5 Duratech and 2.0 Zetec
