Posts: 1,664 |
...and I would agree to that...but take a look at the professionals, they blow engines all the time, and the cars are designed for that.
Your nuts if you are a weekend racer, and don't think anythings going to happen.
[This message has been edited by Joey (edited April 21, 2001).]
Joey 2000 SVT Black #1811 of 2150
Dad always thought laughter was the best medicine, which I guess is why several of us died of tuberculosis.
Posts: 1,090 |
I'm with Joey...
Race cars, even the mildest applications, are designed to be RACED!!! Yet, they break left and right! All the time! Every day! At every race!
It seems only reasonable to expect our humble cars to break with MUCH less abuse than a race car...
Posts: 1,444 |
I been think about this problem a lot. If lets say 100 V6 contour's have blown their engines that is still a very small number compaired to total number produced. I think there are something like 4,000 SVT contours and if 100 blow their motors that's only 2.5% which would be an "acceptable" number. These are just ramblings so please get in my face about the numbers, I just guessing production numbers.
The comment about weekend racing was like a light coming on in my head. I just never really gave it much thought but guess what guys, when your at the track watching a car go around or watching it on TV you did not see all hours spent fixing blown rods, ground up bearings and blown gaskets. But like I said before..there are just ramblings so don't go crazy on me...k?
When I was a young man I had a 84 VW GTI. Raced at every light around every turn and blew the motor at 70K
Posts: 4,476 |
there are a LOT of V6 cars - over 11,000 SVT and hundreds of thousands of 170HP V-6's
we see the most verbal ones....
Todd Christ SVT Contour Registry MODS: KKM Intake, SHO Shop Y-Pipe, Bullit Fuel Door, Edelbrock RPM Resonator '98 E0 SVT Contour #1037 of 6535
Posts: 372 |
Originally posted by Toadster: there are a LOT of V6 cars - over 11,000 SVT and hundreds of thousands of 170HP V-6's
we see the most verbal ones.... BB, Wesley, Mike, Wrecka , Michael ..et al: how many of you had your engine let go during or subsequent to a long right hand turn? Were you pushing hard or did the motor just let go? jj [This message has been edited by jjost (edited April 21, 2001).] [This message has been edited by jjost (edited April 21, 2001).]
Posts: 2,260 |
I was on the freeay going straight at about 75 mph.
SVT with CE light mod and a camera mount. Naughty Pictures Why yes it is true, I am on my third engine.
Posts: 283 |
Sorry I'm joining the thread late. FWIW... Originally posted by Joey: How many people with blown engines, and destroyed differentials, race their vehicles in some way?
I always like the ones that complain about it happening, and list their 1/4 mile times in their sig.
...Similarly, what proportion of folks you see being pulled out of ditches in the winter are driving SUV's? I suspect the correlation isn't between synthetic motor oil and blown engines... It's that drivers who hit the rev limiter with some frequency put Mobil 1 in, thinking it will protect the motor from the abuse. It may prolong the motor's life to some extent, but sooner or later you gotta pay the piper... I've used Mobil 1 5W/30 from the 2nd oil change onward. I'm still flushing out the sludge from just 6000 miles of dino oil! All my manual says is to use oil with a certain API seal on it, and Mobil 1 5W/30 does. ------------------ //> //> //> //> //> Garrick Houston, TX E0, Silver
//> //> //> //> //> Garrick Silver E0, #3895 of 6535, built 10/2/97 She's stock. Why mess with a good thing?
Posts: 206 |
Originally posted by ov3n: I think it depends on how someone treats their engine. If someone constantly beats on their car of course it's going to blow; it's just a matter of time. However I don't think the 1/4 mile time has anything to do with it. In order for the 1/4 mile to blow their engine, it would have to be constant use,
That's true enough for the engine failures, but the diff failures mentioned above can be directly attributed to 1/4 mile runs. Unless the car hooks up perfectly, there is a fair risk of causing impact damage to the diff, especially if any wheelhop occurs. I've seen 1st hand (from testing we do) what impacting can cause - the diff may not necessarily granade on the spot, but hang on enough so that it fails later on, when you least expect it... The impact can cause cracks at bottom of the gear teeth, but may not fully break them off. Normal driving will then fatigue the weakened teeth until they eventually fail. Anyway, that's enough OT rambling... ------------------ Rick Barnes Zexel Torsen Inc '66 Ford Ranchero '72 Yamaha R5C '84 EXP Turbo Coupe '86 EXP sport coupe - turbo conversion '88 Mazda 323 GTX '99 Contour SVT [This message has been edited by Rick @ Torsen (edited April 23, 2001).]
'66 Ranchero '72 Yamaha R5C '84 EXP Turbo Coupe '88 Mazda 323GTX '99 Contour SVT '02 Ranger FX4
Posts: 2,156 |
been to the track since 13K miles on the car and havnt had a problem yet. well now that i have the SC i have had electrical problems.
------------------ Sam 1998 Contour SVT #180 Vortech Supercharger, dynoed at 250.2 fwhp & 196 fwtq @ 6.5 psi now pushing 9 psi, 17" TSW Imola w/Michelin Pilot's, B&M shifter, custom exhaust, Taylor 8mm wires, eibach springs, 2-12" JL Audio subs, KKM pedals, 5% tint w/eyebrow, DTM exhaust tips, OMP strut brace
Sam 1998 Contour SVT #180 1/4=14.2 @ 101.17MPH
AOL users = PhatSVT _ _ _____________ _ _
1986 Mustang GT 12 second club
Posts: 141 |
I had the good fortune to be able to talk with the guy's at Bondruant, and they where adamant about synthetics. They also suggested an oil accumulator, a (larger) oil cooler, as well as a larger oil pan and windage tray, which allows them to use more oil, they run seven quarts! I also scamed a ride... what a blast! I run 5w50 castrol synthetic in both my 'Tours, no problems in 35,000 mi.
Green 1998 SE Sport V6 MTX K&N,KKM oil cap, Ford Racing 9mm plug wires, No RES, and a Hood Bra. Champagne 1997 GL V6 MTX FOR SALE: CEG discount
If Barbie is so popular, why do you have to buy her friends? sw
