Posts: 2,481 |
I was one of the first to get mine back before summer on my old 95SE, but as time went by, everybody and their mother had them. I never got pulled over once driving with them. But, I recently cut one of the wires because they now look gay as hell. I will keep them on the car because I like the silver look with no light, rather than the cheap OEM black look.
99 Range Rover 4.6 HSE Mystery Car??????
Posts: 594 |
I do not know about the windshied washer lights but police have been a bit ticked off about the wheel lights. I beleive ther eis a law somewhere, at least in CT that says only police can have red lights on the car other then tail lights of course. But the thing is the wheel lights are legal in CT. I like the idea of haveing the crome windshield washer to the oem one. I would definatly go with them connected to a switch, but I would connect the power source to the parking lamps or the head lights so the switch will be over ridden when you turn your lights off, and maybe forget to turn those lights off. For my driving lights I found a open fuse on the insdie panel that was hot when the ignition was on, put a fuse in and took power off of the other side.
Son - 1995 Mystique LS Zetec 5-spd --> newest "mod" -> a girlfriend by my side Father - 1995 Contour SE Duratec 5-spd Mother - 1999 Contour SE Sport Duratec 5-spd My CEG Registry My Car My Home Page
Posts: 581 |
Only thing those are good for are TICKETS
-Mancho- cars name is Connie 99 Silver Frost SVT #1986 k&n filter with cut out box true duals w/ flows  Ground Controls with 17's mille miglia ... Hightower headlights 15.4 at 90.29 at Milan dragway before the true duals
Posts: 1,445 |
Originally posted by RockvilleSVT: Well take the power wire and connect to a peice of styrofoam...put it in a package so you can sell them on Ebay. Just tryin to save you the embarassment of being called a homo by your local town. lmaoooooooooo why is this a mod and why would anyone want to do it??? u da man rockville as a stocking stuffer for xmas my girl bought me a bright blue led keychain flashlight....one tiny lil bulb and its bright as idunnowhat...color matches my car and im dumb enough to amuse myself for hrs with it....well not now since im nearly blind from it
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!! are my dodgers for real????
Posts: 3,567 |
Originally posted by brapple: I beleive ther eis a law somewhere, at least in CT that says only police can have red lights on the car other then tail lights of course. But the thing is the wheel lights are legal in CT. In CT, only red lights can be installed aft of the rear axle, however, turn signal lamps can be yellow in the rear. Wheel lights are not necessarily legal, there is just not a law for them, however, if they are blue, then you fall under the blue light law. Be aware, you can put any number of any color lights on your car you want, as long as they are not on while on the road.
"careful man, there's a beverage here." e-mail: boseraq@hotmail.com aol IM: madhat1412
Posts: 263 |
hey gdub i got one of those lights too, its cool ad sh!t. oh yeah and on topic, id wire those lights to your turn signals, less chance of being pulled over and it kinda looks cool...
mzatt
-95 Contour GL -00 Integra LS
Posts: 16 |
I bought the blue ones and I just hook them up to a toggle switch so I can turn them off and on when needed to. I like them. It looks great with my white contour.
Derek Overman
Posts: 127 |
I have mine wired to my running lights and then channelled through a toggle switch. I had blue ones which looked great but then i had some wiring problems and now i have green ones. Unfortunately i am having the same problem with the wire connecting directly to the nozzle. The solid part where it is saudered i believe. I would not recommend getting caught with them though, in Washington its 86 bucks each time.
2000 Svt kkm intake w/heat shield, custom MAF,under-drive pulleys,braided brake hoses,carbon fiber brake pads,painted calibers,17x7 borbet t's with g-force tires,bat euro struts,eibach pro-kit,custom burned superchip,sho offroad y-pipe, bassani exhaust with high flow cat,formula one tint,kenwood excelon cd/mp3,mb quart compents w/mtx amp,b & m short shifter, carbon fiber pedals,hyper-bright bulbs,painted oval ring and many mods to come.
Posts: 1,173 |
Nothing is sacred anymore.
Sal Khan
'00 Silver SVT - KKM, SMA Torque brace.
'00.5 Aprilia RSV Mille - Renegade 2-2 Exhaust, Renegade Air Kit, lots of chips, Evoluzione Ignition Amp, 44t Rear Sprocket
Want to see what I did for lunch today? Check out http://www.mindspring.com/~salk/Lunch/LunchJournal.html !!!
Posts: 4,476 |
i'd be afraid of superheating the washer spray from all the heat generated from the rice, um bulb
Todd Christ SVT Contour Registry MODS: KKM Intake, SHO Shop Y-Pipe, Bullit Fuel Door, Edelbrock RPM Resonator '98 E0 SVT Contour #1037 of 6535
