#377812 07/09/02 03:32 PM
hey did anyone break out the orange pieces in theyre blinkers? i did and it makes it look so much cleaner! man i cant wait for my pics to get in!!! melissa
Melissa
98' contour lx,
svt side skirts/front bumper,
17" optimal wheels,
removed: emblems, door dings, orange reflector
hyper white lights (all)
pioneer head unit,
600w amp
12" 1000w sub
purple neons/alum pedals
indiglos
http://www.pbase.com/image/3068790
#377813 07/09/02 03:44 PM
Yea I did mine about 6 months ago and they look so much better. So far I haven't had any problems with water build up in the lense, just make sure you seal the holes up real goood.
2000 Silver Frost SVT #77 of #2150
KKM, No Resinator, Custom Heat Sheild, Gutted Out Pre-Cats, Ultra Street Underdrive Pulley, Polished Aluminum Intake Pipe, Ford Racing 9mm Plug Wires, Modified SVT Sail Pannels, Audi A6 side markers, Blue SVT Stickers, Silver Dash Kit, Clear Corners and Blue calipers
#377814 07/09/02 06:16 PM
the holes you drill in the back right?? i didnt do that, i guess i have to do it now, thanks!!!!
Melissa
98' contour lx,
17" optimal wheels,
pioneer head unit,
600w amp
12" 1000w sub
indiglos
#377815 07/09/02 06:40 PM
any pics of where to drill hole and what do u do to seal it
jiako|98 svt silver|kkm true rev|18" Enkie RS5 wrapped w/falken GRB FK451 215/40|Mesh grill|
Sony headunit|Boston Acoutics (4)5X7|Memphis 1100 amp|(2) JL 12W3|KVR X drilled rotors|35% tint|2.25" True Duals w/ Magnaflows| kkm pedals|LSD|Fidnaza Flywheel|Centerforce Dual Friction Clutch|FMS wires|Konis/Eibach|ESP bushings and Mounts|75MM PRO FLOW|DMD|Aluminum shifter & E-brake handle|SAFC|HID's and a few more cc's 196.1 and 183.4
#377816 07/09/02 06:45 PM
F
F
There are a few how-tos floating around.
You can eyeball the three holes by locating the three tabs, then drill a 1/4" or 3/8" inch hole. Break the tabs using a small screw driver and remove very carefully through bulb socket after you break the reflector into small pieces using a pair of small needle nose wire cutters.
Not the easiest but you cant hurt your car unless you drill two far or you scratch inside of lens with wire cutters,
just seal with black silicone.
I have done two cars. Mine was a PITA (learning curve), 2nd one took half hr.
#377817 07/09/02 07:09 PM
yea, i had someone do it for me, he did it on his svt. he just didnt tell me about the water gettin in it. he drilled 2 holes in the black part in the back of the headlight, then he broke the orange piece wit a screwdriver. then wit pliers he cracked the piece in to smaller pieces and they fall through the hole for the bulb. its really easy. as soon as i get pics ill post them.
hey guys go on www.prideintheride.com we are a car club in new jersey. ill have pics up soon there too. melissa
Melissa
98' contour lx,
17" optimal wheels,
pioneer head unit,
600w amp
12" 1000w sub
indiglos
#377818 07/09/02 11:56 PM
H
H
yes a lot of people do this mod and there are many ways to do it.
'98 SVT #2253
Currently DEAD!
Cobra Paradise
#377819 07/10/02 08:07 AM
I really don't want to mess with them. Plus I am going for the sleeper OEM look. wink
2000 Contour Zetec ATX
Hector
Mods...I got em'
"Contour grills, Contour bills, check out the oil my Contour spills."
2.SLO = 17.6 at 80mph
My profile
