Posts: 2,683 |
Originally posted by The Red Magi: Ok you added just the Amsoil to your MTX75? Make me a bit leary. I'd think it would be harder to get the gears to mess since the sycros aren't working as well.
I just don't want to ad the modifier to amsoil and findout it adds too much or something.
hmmm... Terry "cocktail" means the modifier right? not the XT-M5-QS. At 15-20 bucks a quart I'd think mobil or ams would be a better deal.
Still unsure myself...
Thanks for the feedback though! Ray All I did was drain the Ford stuff then refill it with Amsoil......easy no regreats no problems,friction modifier not needed!Its been a few years and shifts smooth.
Howard 1998 Silverfrost SVT #1612 June mods: 17" ADR RS Limited Limix Wheels with 215/45/17 Yokohama AVS Sports
Posts: 1,444 |
see the sig. not a single complaint here.
AIM:omegazodiac
95 gl 99 contour svt #1750/2760 built 4/6/99 black/tan plates, not personalized (###-REV) amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
Posts: 1,151 |
I just helped PA3LSVT do his tranny cocktail and he loved it. He used Mobil 1 ATF and Ford's friction modifier. It is time to do mine as I just bought my second SVT but all I can find in the Poconos is B&M, no Mobil 1. (Go figure) Is the friction modifier recommended w/ B&M's ATF as well?
ChickenhawkRacing@hotmail.com 1998: #4415/6535 mods: Sheet metal screws in rear chrome strip Four wobbly corners "Hey, do you like apples?" "Well, yeah." "Well, I got her number, how do you like them apples?"
Posts: 3,419 |
Demon advised to stay away from the B&M. Apparently it is really meant for ATX only. It has a bunch of additives in it that Mobil 1 ATF doesn't, like anti-foamers and friction mod already in there. If you want, I'll grab up some Mobil 1 ATF down here and bring it to you. Or you could order it from here . Oh yeah, and the Mobil 1 cocktail totally kicks ass. Much better than the Torco I was using to break in the new diff!
Posts: 1,151 |
