#3752 03/09/02 09:05 PM
N
NickG Offline OP
N
Can someone tell me what option code to look for on a 2000 contour for keyless entry....I am new to the group. I am not sure if the car came with keyless entry or not...
If you have any info on programing the remotes I need to know that also....
Thanks for the help!!
Nick
#3753 03/10/02 02:01 AM
W
W
Programming the remote is a piece of cake assuming your car came with keyless entry. Under the clove box, behind the carpet there are a bunch of wires. Taped up in there is a white connector. Pull it down, insert key in the ignition, and jam a paper clip in both holes of the connector. This will jump the wires and you will have the car beep. Next click on your remote and Voila, Il est programme.
