Posts: 478 |
The best way to say this is with enough money, anything is possible. If your wanting and willing to drop some cha-ching on motor work and parts, you should be able to get the highest HP rating you want to achieve. With the right internal workings and bolt on stuff, you can have a smokin Ztech. Personally, I'd drop the 4 and do the 3.0L install, and work with that. P.S. enough arguing, last time I checked, we were all here for the same reason, passion for our cars.
2000 SE Sport MTX Current Mods:KKM intake/removed res./custom Flowmaster exhaust/Eibachs/SVT struts/17x7 TSW imolas w/Dunlop SP9000 tires/fog fix/885 fogs/sound by Alpine,PPI,Audio Control,JL Audio,Boston Acoustic,Focal/Schroth 4-point racing harness. Future Mods: Fully Zaino'd/front and rear sway bars(w/ custom BNOON powdercoating)/Strut tower brace/SVT exhaust/underdrive pulleys/SVT upper and lower intakes/Superchip/B&M short shift/SVT front bumper/and some others I haven't decided on yet. www.stlsp.com "Life's too short not to spend money----on your car!!" "It's only wrong if you get caught doing it"
Posts: 122 |
I agree with SQPlus, us in the zetec crew have looked far and wide for stuff. If you have some money and time there are many things available. No where near the simplicity of a honda, but we know that going in. I think just owning a zetec contour in different enough. Now with Terry (your the man, bro) we have not only a fighting chance but a sure victory.
Posts: 105 |
>>BTW I USUALLY AM ON CAPS LOCK BECAUSE I USE IN MY CHAT ROOMS AND I DIDNT TURN IT OFF. THANK YOU VERY MUCH. SOME OF YOU GUY'S ATTITUDES NEED A SERIOUS TUNE-UP!<<
Some of OUR attitudes??? I think you should go back and reread a few of your posts before criticizing anyone else on here. And in the chat rooms I generally put people on permanent IGNORE who won't take the time to use their shift key, whether it's all caps or none at all.
Jeff
Posts: 2,587 |
Originally posted by timfiredog: last time I checked, we were all here for the same reason, passion for our cars. I'm here to make rude jokes and offend people... they usually just ignore me though...
1996 Contour "Mean Green" (99-02) 2002 Malibu Blue Focus ZX5 - something to hold the PB 15...
Posts: 2,657 |
Originally posted by The Honkeytonk Monkey:
I'm here to make rude jokes and offend people... they usually just ignore me though... FWIW, I get a kick outta your jokes...most of the time.
Posts: 20 |
Originally posted by SQPlus: ...and believe me us Zetec owners have been looking into all the different Foci parts available. Unfortunately we've run into problems with almost every single one of them. Throttle bodies, engine mounts, intakes, suspension, plug wires, turbo kits, headers, intake manifolds, cams, cam gears...you name it we've probably looked into it. Overall, we've actually had better luck matching up/using performance parts from the zx2's than anything else.  Enjoy.[/QB] Hmmm?!?!?! Very intriguing indeed! Generally if the engine is the same, the parts are the same! That's a first I've heard. You see, the 2.3L parts I've mentioned matched up 99% of the time. The only diff was slightly diff bolt-ons from the factory but usually all aftermarket stuff works! Has anyone tried to find out why the stuff won't work? Or why the escort stuff works better? My guess is that there must be slight diffs in the design or placement of certain bolt-ons on specific vehicles in the factory. Has anyone tried correcting this?(You know, a lil welding here and there?) Or has anyone tried to exchange the outer-skin of their Contour's engine with that of the Focus so that the bolt-on's mentioned will work?(Outer-skin=intake manifold, heads, intake, exhaust manifolds, etc,)Maybe if we tried to keep the block and change a few of these first THEN bolt on the Focus stuff maybe it would work. I don't know you guys are the experts, I'm just trying to learn. Someone please let me know.
Posts: 2,657 |
I can't remember specifics off the top of my head but it seems Ford just changed little things that make it enough for parts not to match up. Something I hadn't mentioned before is a lot of the aftermarket companies don't have good return policies(for good reason)therefore its a little un-nerving spending $300(hypothetical) on a header that you can't return and then find out once you get the manifold off there are two studs in the wrong spot. Then you have to try and sell it to an individual and potentially lose money on a brand new uninstalled part. Gets expensive and annoying very quickly. This is just an example but you get the idea. One thing I know for sure is different is the engine bay/hood size/arrangement make fitting intakes a problem. Just a few things I can think of. IIRC one guy bought a Focus JBA Header and all it required was a new CAT flange. Its little things like that which aren't always easily fixed by welding a new flange on(as with the latter example). I think maybe Ford did it on purpose.  It's all a conspiracy. :rolleyes:
Posts: 20 |
Originally posted by SQPlus: I can't remember specifics off the top of my head but it seems Ford just changed little things that make it enough for parts not to match up. Something I hadn't mentioned before is a lot of the aftermarket companies don't have good return policies(for good reason)therefore its a little un-nerving spending $300(hypothetical) on a header that you can't return and then find out once you get the manifold off there are two studs in the wrong spot. Then you have to try and sell it to an individual and potentially lose money on a brand new uninstalled part. Gets expensive and annoying very quickly. This is just an example but you get the idea. One thing I know for sure is different is the engine bay/hood size/arrangement make fitting intakes a problem. Just a few things I can think of. IIRC one guy bought a Focus JBA Header and all it required was a new CAT flange. Its little things like that which aren't always easily fixed by welding a new flange on(as with the latter example). I think maybe Ford did it on purpose. It's all a conspiracy. :rolleyes: LOL@conspiracy theory!! Well maybe Ford figured that they goofed on some of the Contour stuff so they changed some minor things. Maybe I should find a Contour with a blown engine for about $500 and buy a Focus engine? Hmmm, thinkin' real hard!!!
Posts: 2,657 |
Good luck! You're gonna need it.
Posts: 413 |
FWIW, Focus ATX is different from the Contiques ATX. About 2 years ago, lil sisters Focus ATX stopped pulling hills, started slipping, etc. Had to wait weeks for a new "Focus Specific" ATX.
