Posts: 2,112 |
High beams aren't good candidates for HID conversions. For one, the bulbs take a few moments to fire up and stabilize, so flashing your lights wouldn't work well and could possibly shorten the lifespan of the ballast and/or bulb.
New BMWs have dual-mode xenons that re-aim the low-beams in a high-beam pattern if they are kept on, but halogen lamps are still retained for momentary operation.
Posts: 1,444 |
69boss302, do u mean 24.99 for each set: hi and low or 24.99 per bulb. 50 bucks or 100 bucks.
so how r the silverstars comparing to the piaa superwhites
AIM:omegazodiac
95 gl 99 contour svt #1750/2760 built 4/6/99 black/tan plates, not personalized (###-REV) amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
Posts: 653 |
It's 24.99 per bulb, so 100 bucks for all four. I just put mine in this evening and must say that I am quite impressed with them, especially on hi. They are soo much better than the stock things that pass for light's. As for comparing them to the PIAA's, not sure. I haven't seen the PIAA's other than in brochure's. Maybe someone else can answer that question. Mike
I have a dream, and that is a 69 Boss 302 with Jules Asner in it. Current - 2002 Chevy Silverado Former - 98 SVT E0 T-Red 4/4/97 #173 of 6535(so long girl, you'll be missed)
Posts: 4,899 |
PIAA? Bahhh, overpriced. I had a set, put them in, and actually returned it because I was disappointed. Stick with things like Siverstars or CoolBlues. To be honest, the Philips Vision Plus/Sylvania XtraVision are some of the best lamps I have ever used.
