This is a Mk1 Rabbit with a 5v 1.8 (NON TURBO!!) motor swap at the track, passing cars with authority.
Great track vid of an extremely fast bunny!
Right Click and Save as please! This is what I want my 84 Jetta to be like when I'm done with it.
Here is the specs on the car:
Engine:
Audi A4 2.0 liter 20v with baffled sump and windage tray, lightened and balanced bottom end and modified 16v pistons. Ported 20v head with crane billet cams and kent vernier pulley. 45mm Jenvey throttle bodies and MBE engine management system. Custom made 3 core radiator, slimline fan and silicon hoses. One off 4-2-1 exhaust manifold with supersprint exhaust and heavy duty mounts. Produces 178bhp@wheels
Chassis:
Mk2 020 16v transmission with a 4:2 final drive, Quaiffe LSD, modiefied driveshafts, rose jointed gear linkages and short throw lever, Koni top adjustable dampers, Eibach springs and anti-roll bars. Bonrath top mounts, modifies front struts, Scirocco 16v front lower strur brace, triple point rear strut brace, Polyurethane bushes everywhere. Competition pedal box. Volvo 240 four pot calipers on Rover 216 discs front and MK2 16v rear disc conversion. Goodridge hoses and padgid pads all round.
Styling:
Stripped down and resprayed using VAG panels, Audi tilt and slide sunroof, BBS RS split rims with Goodyear 195/50/15 rubber, standard interior and brake bias valve
