Posts: 803 |
Hey Chris if I want to order this and other stuff can you bring it to a meet?
hunter green 96 mystique mtx, sabb side markers deep tints car bra., K & N filter, hyper white low beams, after market fogs, JVC Kameleon head unit, 600 watt amp with 2 10" kicker subs, soon to come new rims
New adition 01/11/2002 The original 95SE in Midnight Red all the toys including traction control Fog light mod, lightmoonroof switch from a focus, power antena (still wiring it up) post 98 sail panels, new water pump , Bosch quad plaitnum plugs, and a new Cat.
Posts: 1,202 |
Originally posted by mbb41: Hey Chris if I want to order this and other stuff can you bring it to a meet? I sure can.
Posts: 5,296 |
I wish you would have made it before I bought the BAT pipe... I'd take one in powdercoat blue if I don't have the BAT pipe already.
Posts: 803 |
Originally posted by cawong11: Originally posted by mbb41: [b]Hey Chris if I want to order this and other stuff can you bring it to a meet? I sure can. [/b]Kewl too bad you don't have midnightred as a powder coat option.
Posts: 1,831 |
I have the worthless BAT pipe with the fittings that dont fit any of the Stock SVT hoses!
Please oh please tell me you are going to make the hole for the IAT work, unlike BAT's.
Will the base model with red silicon be cheaper than those powdercoated? Excellent price at the $75!
Posts: 1,202 |
Originally posted by Fmr12B: I have the worthless BAT pipe with the fittings that dont fit any of the Stock SVT hoses!
Will the base model with red silicon be cheaper than those powdercoated? Excellent price at the $75! Most likely, standard polished aluminum will work out cheaper, how much though, we are still deciding on a price.
Posts: 908 |
well when things get rolling with that you can count me in for one in Red.
Mike | 98 Silver CSVT
Posts: 85 |
Do you have any pictures of the blue? Very nice job on the coating!
Posts: 1,202 |
Originally posted by 98SVT100: Do you have any pictures of the blue? Very nice job on the coating! We only had the red samples, 3 and 4 hole as blue would have to be done in another session. If you look at how we attached the stock hoses to the BAT pipe, it will be the same as with our pipe. One difference being the IAC hose. Because we placed our holes vertically, the stock hose, witout the plastic end fitting, will slide over our IAC hose fitting. The IAT will fit by using a small silicone grommet fitted over the IAT sensor. I fitted mine last night and it was snug, but is well into the air stream.
