Page 4 of 5 1 2 3 4 5
#37278 12/31/01 04:35 PM
"3)This type of cooler does give a restriction to flow/pressure Vs oil/air type 4)Never hear of many non SVT's with oil pressure probs...just food for thought..."
OK Terry, you are giving me a headache.
frown The oil cooler has been mentioned before as a possiblity because it "holds" a bit of oil - less available to sump? Is this "restriction" a real concern of yours or more hypothetical? Can you test this by measuring oil pressure before & after cooler? The "doughnut" cooler is a Mondeo part as I understand, do Mondeo V6s have more oil related failures? But if its a problem its easy enough to remove.....
The other unique thing about SVTs is that they rev better (light flywheel), and as they make power to redine (better breathing), probably spend more time at higher RPMs. This may have implications on both the oil situation (increased pooling in the heads?) and on the crank harmonics. How many failures are crank whip related and how many are oil starvation?? confused
1999 Amazon Green SVT Contour (#554/2760)
Stock SVT Duratec V6 with:
Intake- K&N filter/75mm MAF meter
Exhaust- MSDS Y-pipe/Bassani catback
Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter
179.2 FWHP at 6900 RPM
#37279 12/31/01 04:44 PM
From Nick (monkeyra)the Mondeos in UK hardly ever have and engine or trans failure.Yes the donut type does have more restriction to flow Vs a conventional/Laminova type...sorry about your headache!!! wink
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
#37280 12/31/01 06:02 PM
Administrator
Administrator
My main beef with the K&N oil filter was that it does not come equipped with an anti-drainback valve. On my 95, the K&N caused excessive timing chain rattle on cold startup. Disappeared when I went back to the Motorcraft.
-Lance
Lance Kinley
CEG Webmaster
95SE, "Official CEG Beater"
Quaife, SVT parts, ST200 wheels, SS Y-pipe
I perceive you to be a stand-up, rational individual...
#37281 12/31/01 06:11 PM
I
I
What about the oil pan on our cars? I recently read an article in SCC magazine about a guy in a Neon making a sweeping right turn and blew his engine immediately.
The investigation took place and SCC determined that the oil pan had no baffles to prevent air from sucking in during hard cornering, and no windage tray to help with oil return and reduced windage losses.
Coming to conclusions, I am suspecting bearing failure is due to the stock oil pans design.
99 Range Rover 4.6 HSE
Mystery Car??????
#37282 01/01/02 06:00 AM
-Lance
Yes it most definitely has an Anti-drain back valve.
2000 SVT #674 - Check it out!
#37283 01/01/02 06:06 AM
Modified oil pans and/or baffles have not cured the problem.
Also the stock pan has some small baffles already.
#37284 01/01/02 08:49 AM
I am very happy with using the K&N oil filter on my zetec can it is a b!tch to get the filter off without that nicee nut on it. I have been using the k&n filters for over 2 years without any problems. along with mobil 1 synthetic 5w 30
96 Contour
it's faster than a period.
some day I will be as fast as D Davis
#37285 01/01/02 01:01 PM
6
6
I swear by Fram, used them for years and never had a problem. I also use Valvoline full synthetic 10w30. But that's me.
Mike
I have a dream, and that is a 69 Boss 302 with Jules Asner in it.
Current - 2002 Chevy Silverado
Former - 98 SVT E0 T-Red 4/4/97 #173 of 6535(so long girl, you'll be missed)
#37286 01/01/02 07:02 PM
I wouldn't say that out loud...
FRAM is one of the worst filters on the market!
Go back to the stock filter!!! You will thank yourself for it.
#37287 01/01/02 07:34 PM
Fram are known to literally come apart.
Go back to the Motorcrafts. If you can afford it, the K&N.
