Originally posted by livinsvt:
1. The oil filter tests, you would be having to use the same kinda of oil, same mileage after use and exactly the same test.
2. If there is a over oiling condition why is is not stated in the k&n recharging kit. It states in step #4 spray k&n oil on filter covering each pleat. wait 10 minutes and spray again. Thats a lot of oil. Says nothin about over oiling. But to service it every 50-100,000 miles
I suggest you go back and actually read what I posted! :rolleyes:
All oil was 5W30 Mobil 1 from the same batch (I buy in bulk)
FL-820S was borderline in viscocity & flash point after a mere 3000 & 3500 miles
K&N Oil was the best results by far. (4k interval)
So the K&N's oil had more miles yet better viscocity, flash point & less contaminents.
All tests done by Blackstone Labs!
Slam dunk!
2. Did you just make some of that up?
It specifically states. Spray bottom of each pleat. 1 pleat per pass. Let oil wick up the filter. Wait 10 minutes and apply to any white spots showing
If you check out an actual filter box, K&N's site, or a K&N catalog it states:
"When servicing a K&N filter, take care not to over-oil the element. Never saturate the filter. If oil drips from any part of the filter, wash it and start over. Use only K&N oil. For example, an E-1500 filter has 92.4-inches of surface area requiring 1.707 fluid ounces oil. Follow the oiling instruction included with your filter."
BTW - 1.7 ounces is only ~20% of the oil supplied in a standard recharge kit and the E-1500 filter is one of their larger filters.
I've used my kit for over 5 years and 4 different filters with multiple cleanings on some of those filters.
Never once have had an over saturated filter or MAF problems because of it.
Another note. My wifes car with over 80k miles on it consistently received outstanding oil results and engine wear ratings using a K&N air filter, Pure One & Mobil 1. So obviously even over a long term test the filter does an exceptional job.
...and like I stated before... I don't sell them either, just have hard data they filter better then people give them credit for. (your "instructor" included!)
As for their oil filters. The little data I have using them vs the stock FL-820S has them a hands down winner so far. I also gave you my educated guess why earlier.
My educated guess is with the FL-820S more oil is getting "bypassed" (which is NOT good) and the more restrictive filter media is causing extra heat and degradation.
I seem to recall a SHO site with this same type of findings with their Yamaha motor & oil filters... Have to dig up that link...
