Page 3 of 3 1 2 3
95 mystique has clear needles...or so you HAVE to have 240sx needles?
1999 Silver Frost SVT
#609 of 2760
Born on 12/3/98
KKM Intake
Removed Resonator
35% Window Tint all around
Tinted Tail Lights
ElKy Mesh Grilles
HID
Dyno'ed at 175.3HP/155.5TQ
Call my silly here but if there are clear needles available for cars with the same cluster, then why would an SVT owner need to buy anything except the same needles on his car but clear/black?
Can these clear/black needles be had from Ford still?
How about painting the SVT needles instead of replacing them....??
Why do 10¢ LEDs cost 70 bucks, BTW? just curious...can we make something on our own, ala Chris H. or Brad N. and save our money/funnel it to fellow CEGers?
OH, and looks nice hehe!
Andrew
99 SVT
H
H
thats a good question. i definitely want to do this in red. looks hot.
so anyone know about the gauge accuracy. is this something to consider.
AIM:omegazodiac
95 gl
99 contour svt #1750/2760
built 4/6/99
black/tan
plates, not personalized (###-REV)
amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
I
Icefury Offline OP
I
The "how to" is aimed around the Cougar. The Cougar has solid red plastic needles and the 240SX needles are the closest fit I could find. I'm sure the 240SX needles are not the only and or best choice for the Contour. I use them as a point of refrence cause I know they work. If the needles you have are clear then you DO NOT need the 240SX needles, just buy the kit! As far calibration is concerned my needles are very accurate. I do have a small problem with the fuel gauge needle as it tends to sometimes fall below the resting position when the car is off. Sometimes it will stick and I will have to tap the gauge cluster to free the needle. The other 3 work perfect. I think I just need to reseat the fuel gauge needle as the temp gauge needle is the same size and works perfect. In refrence to the cost, it is high priced for what you are buying. Brad estimates rougly $10 in parts. However as some of you may know Brad and Chris.H made a led kit for their needles. The problem if I understand correctly is it a major PITA to make and to date they have expressed no intrest in making such a kit. As I have said before Import Intelligence is the only people who make this kit and because they "own" the market they can charge what they want. They make a killing off of this kit for sure but unless you have the time and patience to make your own, Import Intelligence is the only source for the glow needles.
99 V6 MTX Dark Tourmaline Cougar
My Cougar
Lee Offline
The 4 Cyl and 6 cyl Sport (Tachometer) Instrument Clusters come with white backed clear needles. Just FYI...
Lee Cox
In life begins responsability...
Project Car
I
Icefury Offline OP
I
I've been real busy but I finally got around to finishing this little project. The pics really only give you the general idea, they look *much* better than the pics reflect. I will be revising the *How To* I wrote for this project before the day is out with some additional info. [img]http://www.fastcougar.com/forums/attachments/PIC00004%2EJPG[/img] [img]http://www.fastcougar.com/forums/attachments/PIC00006%2EJPG[/img]
My Cougar
Lee Offline
Still looks very good.
Lee Cox
Project Car
Why not indiglo gauges with red needles? wink
Sorry just saw an opportunity to whore my car. laugh
2000 Contour Zetec ATX
Hector
Mods...I got em'
"Contour grills, Contour bills, check out the oil my Contour spills."
2.SLO = 17.6 at 80mph
My profile
Page 3 of 3 1 2 3
