Posts: 82 |
This kit will work with "any" color. You would be replacing your stock needles with those from the a 89-94 Nissan 240 Sx. It's the stock needles that limit your color choice to red. The 240 sx needles open your color choice wide open as they are clear. Any color can be used with these needles but the Indiglo Kit sold by Import Intelligence and it's resellers offer only Red,Blue,Green.
Posts: 3,165 |
oooooooooh, I likey
Posts: 4,528 |
Won't the difference in needle weights between the 2 manufacturers throw off the guage accuracy? If you look on the underside of the Contour needles you will see very tiny brass colored weights. Just wondering. Looks good BTW!
Posts: 30 |
Excuse me guys, this is not :IndiGlo" these are "IntelliGlow", done with LED's, not the patented "IndiGlo" process. It is very cool nonetheless! -RR
1998.5 E1 Torreador Red #4507 of 6535 B&M Shifter, ShoShop UDP, KKM Intake, CarDoc Exhaust
Posts: 569 |
So why won't it work on contours, my gauges are clear with a backing on the bottom of the needles that will come off very easly
**Spelling should not count**
2000 SE Zetec ATX Medium Steel Blue (Now with large custom dent on the rear door) Cool Blue Lows, Silver Star Highs (great lights)
"If what I said was wrong, it wasn't. I just forgot to add the rest of my post."
Posts: 4,528 |
No one said it wouldn't work did they?
Posts: 2,657 |
I think hes refering to SVTs which have red needles...other contours have clear needles. I think cougars have red needles too.
Posts: 82 |
Yes the Cougar's do have red needles. Thats why switching over to the clear 240SX needles is nessicary.
Posts: 999 |
So the question is, would the kit from Import Intell. work on our cars, or would we have to convert to the 240sx?
I am a little confused about all this.
14.72@ 92.6 mph www.modularV8.com "CLUTCH KILLER" and also recently known as the DRIVETRAIN KILLER
Posts: 82 |
If your stock needles are clear plastic than you need not worry with 240sx needles and can order any color they sell. If your stock needles are red plastic then you must replace them with the 240sx needles that are clear and will allow any color to be used as well.
