Regarding the "bundle of snakes" exhaust Ford used in the 60's. This is an effort to get equal timing between the exhaust pulses in the header. W/ 90 degree crank on a V8, thehe firing pulses are not equal on each bank. (IIRC each bank has 180, 180 90, 270 between firings.)
Now to the simple solution: use a 180 degree "flat" crank. Essentially it turns the engine into two 4cyl engines joined at the crank. It does vibrate more, but according to Ferrari (the only maunfacturer who uses a flat crank on a street engine) it is worth about 5% horsepower, gained through better exhaust scavenging. And the engine sounds better! This is why a CART/IRL engine sounds so different from a "regular" V8. The initial IRL engines were 90 degree cranks and they sounded likes high speed trucks.
This has little to do with the initial question, just a bit of near useless trivia.
As to the original question, go to Amazon and buy this book (you will then know more than 99.9 of enthusiasts about intake and exhaust design):
http://www.amazon.com/exec/obidos/ASIN/0...5205160-6460128 My $.02
Richard
