#369989 05/06/02 02:26 PM
Anyone have some step-by-step instructions on how you prepped your dash peices for painting? How about some product reccomendations.
98 Contour SE Zetec ATX
"Chevy Corsicas Fear me!"
"There's no such thing as a PRETTY GOOD alligator wrestler"
#369990 05/06/02 02:29 PM
N
N
I used primer on my read door handles, it didn't work!
but I'd clean the surfaces really well with some rubbing alcohol, to remove any grease or built up dirt. Maybe a light sanding with a real fine grit sand-paper and then paint and let it sit till it's compleltely dry. If you don't have to use the car for a couple of days that'd be even better so the paint could cure before you reinstall it.
#369991 05/06/02 02:39 PM
Sand the pieces with 400 grit
I didn't primer this time
2 coats of color
wet sand 600
2 more coats color
2 coats clear
Spattmobili®
#369992 05/06/02 04:36 PM
1. Wash all parts in dish detegent to remove any oils from the surface
2. Sand w/ 400 grit
3. Primer
4. 2-3 coats color
5. 2-3 coats clear coat
I used Duplicolor spray paint and primer because the spray nozzle puts out a nice, smooth stream. Mine looks like it came out of the factory painted.
Matt - svtcontour@mindspring.com
2000 T-Red SVT #2010
B&M Shifter * KKM filter * KKM Pedals * A6 sidemarkers * Bill Jenkins SVT mats
Atlanta SVT Owners Association
#369993 05/06/02 05:12 PM
Really helpfull. Thank you much!
#369994 05/06/02 05:16 PM
check out the custom interior post by jpett under pics and videos.it has a bunch of info.if you can't get what you need from there, just pm jpett i'm sure he would be glad to help. smile hope this helps. smile
Adam
Electric red
95 Ford Contour GL
ATX Zetec
Born on date 11/1/94
Big changes coming......."hint 95 Ford Contour SVT".
"This is a place for crazy people I'm not crazy." Brad Pitt [12 Monkeys]
