Posts: 40 |
At the end of the headers on my stock 98 se tour' is there a converter there that the sensor plugs in at?.....or is that just heat sheilding material? that makes it look like a catalytic converter before the join point after the collector?
Cam Case Okc, Ok
98 tour SE Resonatorless Gutted cats some speakers A little bobbin head cat watchin every1 pass and ford mud flaps(darn fishin trips keep me muddy) added all terrain tires(i like to pretend im rally racing, whne not really racing)
Posts: 600 |
I don't know exactly what your saying, but I'll take a guess. I believe you are reffering to the oxygen sensors in the stock manifolds. There are 'pre-cats' in the manifolds, which basically only controll emissions when the car is cold. Hope I guessed right  !
97' 2.5L Contour SE -T-Red Midas exhaust (grr...), Sony CD player, K&N airfilter, Mobil One Synthetic Oil, removed intake resonator, modified MAF, in-fender CAI, painted grill, Platinum tipped NGK's. I am looking for SVT E0's or E1's, SVT Upper & Lower Intake, SVT Throttle Body, and SVT Exhaust. If you are selling, e-mail me! Ford4eva@hotmail.com
Posts: 40 |
Thank you for the input.......does anyone know much about collector angles for differrent y-pipes?....is there a difference in brands that may give more torque?
Cam Case
Posts: 1,201 |
Contact Chris at CTA motorsports. He has done extensive dyno testing with most y pipes and several with msds headers. http://www.ctamotorsports.com/
If it's true that we are here to help others, then what exactly are the others here for?
