Originally posted by AnandH:
Please say your not using your accessory wire from your deck. im having a hard time seeing how they turn on with your deck otherwise.
i doubt you are, cause if you were you probably would have damaged the acc. output already.
if you are however, i hope your using a relay
wrong i doubt those leds, will draw
that much power
surely thats not the best way to do it...even if it were drawing too much power, the fuse should pop
hold the wire after the leds have been on for a while, if it gets hot, then unplug that baby
